Installing new deck hardware for a dummy. - Page 2 - SailNet Community
 7Likes
post #11 of 16 Old 04-27-2013
CS Cruiser's Avatar
Dock
Re: Installing new deck hardware for a dummy.
Originally Posted by dvuyxx View Post
Does anyone ever make teak covers (or some other kind of cover for these plates and bolts. I have a few in my cabin. Or do most people just leave them as is?
I cover mine with 4" & 6" teak winch base pads, just recess the back side and match up a few of the hex bolt caps for a pressure fit, easily removed if you have to and they never have fallen off.
Paul
s/v TENACITY - CS36T
CS Cruiser is offline
post #12 of 16 Old 04-27-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
the Seasprite 23 "heritage" the owner used wood to back the deck hardware you can see from inside the cabin. This was what he did to back a cleat:
dvuyxx likes this.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #13 of 16 Old 04-27-2013
That sure does look nice!
MarkSF is offline
post #14 of 16 Old 04-27-2013
Asleep at the wheel
jimgo's Avatar
You could even put the wood over the stainless plates if you want to be really "thorough".
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #15 of 16 Old 04-28-2013
asdf38's Avatar
I think it's worth remembering that fender washers are not a bad option.
It depends a lot on the geometry involved but I think the plate is best in these cases:
1) Hardware is really spread out, or unevenly spread out
2) You intend to build the plate significantly larger than the hardware
3) You can't fit large circular washers because of limited space outwards.
However when these arn't true, not only do I think washers can be "fine" I think they can be better than the types of plates you often see. For one, a circular washer is a pretty good way to transmit force and does so nice and evenly.
Second, consider the scenario I just encountered - a circular piece of hardware, roughly 3" in diameter with a 3" circular backing plate. The problem with the plate is that it's only transmitting force in a 3" circle. Fender washers however, comparatively, spread the force outward (if there is space to do so). If I install fender washers and then draw a circle around them I'll have something with a diameter of 4" or more. Yes there are some gaps in this circle but the fiberglass will effectively bridge some of these gaps and overall if I replace this compact backing plate with large fender washers I expect it to be a net positive.
I think a properly designed backing plate always can be better than fender washers, but not necessarily significantly, and perhaps not worth the cost.
If you don't take my word for it I believe I've seen Mainsail say something similar - that fender washers with a sound deck are perfectly fine.
G10 backing plates
Note: McMaster.com sells 316 fender washers for 1/4" hardware up to 3" in diameter - that's huge.
asdf38 is offline
post #16 of 16 Old 04-29-2013
Stu Jackson's Avatar
I agree about the fender washers. You need to analyze the loads. On most deck hardware, the load is in shear, especially for cam, clam and sheetstopper clutches. The backing plate is only there to avoid the tightened bolt/locknut and nut from digging into the fiberglass below.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
Preferred method for installing mast hardware? josrulz Gear & Maintenance 2 10-29-2009 11:11 PM
deck hardware blizzard Gear & Maintenance 1 10-18-2001 08:54 AM
