epoxy anchor well bottom - SailNet Community
post #1 of 14 Old 03-30-2013 Thread Starter
AKAPeterc's Avatar
Send a message via Skype™ to AKAPeterc
I have just purchased a 44 Hunter DS and cleaned out the anchor well And found that there is a lot of junk below the drain hole, Has anyone epoxied up to the level of the drain hole To stop the anchor sitting in any water.
AKAPeterc is offline
post #2 of 14 Old 03-30-2013
Tundra Down
downeast450's Avatar
Re: epoxy anchor well bottom
Yes! I had the same concern. The same solution, too. I mixed some WEST epoxy with microbaloons to a pourable consistency and brought the floor level of the locker space up to the drain hole. I cleaned and prepped the surface for good adhesion.
Down
downeast450 is offline
post #3 of 14 Old 03-30-2013
Down
This is the way to do it, just read the guidlines from the epoxy vendor.
There is a maximum thickness that you can cast in one go as epoxy developes lots of heat while curing.
knuterikt is offline
post #4 of 14 Old 03-30-2013
celenoglu's Avatar
The drain hole is higher for a reason. All the nonfloating particles stay there and the drain hole can easily remove the water. If you still want the drain hole as low as possible, drill a new one close to the bottom. This will drain the water. In case something blocks this opening, which will be the case, the original drain hole will work.
celenoglu is offline
post #5 of 14 Old 03-30-2013
Correct
I have one hole at bottom on port side. One hole elevated 1 inch on starboard side. This helps with some of the debris entrapment. Still have to go in and hose down once in a while.
benesailor is offline
post #6 of 14 Old 03-30-2013
I live in a country where we have freezing temperaturs in winter, I prefer to have the drain hole at the bottom to avoid expanding ice from doing harm.
Never felt the need for two drain holes
post #7 of 14 Old 03-30-2013
I have mine fitted with electric plugs so i can close the holes at will.
Detergent and 2 loads on a rough day makes for really clean clothes.
post #8 of 14 Old 03-30-2013
Just kidding
post #9 of 14 Old 03-30-2013
Tundra Down
There is a maximum thickness that you can cast in one go as epoxy develops lots of heat while curing.
That is correct! It is an exothermic reaction. I should have mentioned it. I did it in two pours. It built up a wedge of epoxy mix about 1" thick at the forward edge. It is a fairly flat and thin pour and dissipates heat well.
Thanks,
Down
post #10 of 14 Old 03-30-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
While I agree that you want the hole higher to keep it from clogging.. if you are going to build up a layer, I might suggest some sort of foam be glued into place first and the epoxy poured over it. Less weight, just as strong, and a small amount of extra buoyancy is added to the boat
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
Hard epoxy bottom paint--a barrier? FrankLanger Gear & Maintenance 7 08-25-2007 12:18 PM
epoxy bottom? when to do it? mrkeith Gear & Maintenance 14 02-04-2007 07:01 PM
Blisters, bottom jobs, epoxy, and barrier coats pmoyer Boat Review and Purchase Forum 4 10-20-2006 08:22 PM
