New Prop Shaft Cal 2-30 Atomic 4 - SailNet Community
 1Likes
post #1 of 14 Old 03-30-2013 Thread Starter
Sootydan's Avatar
Question New Prop Shaft Cal 2-30 Atomic 4
I need to remove my prop shaft on my Cal 2-30 that has an Atomic 4. I'm replacing the Cutless bearing and installing a PSS shaft seal. I'd rather just cut the prop shaft and replace the shaft and coupling rather than damage the transmission end etc. I've read the ways to remove the coupling from the shaft in the boat but there's still the possibility of causing problems on the engine/trans side and I want to avoid that. Where can I buy a new prop shaft?
Sootydan is offline
post #2 of 14 Old 03-30-2013
Lake Superior Sailor's Avatar
Re: New Prop Shaft Cal 2-30 Atomic 4
Why would that help, you still have to remove it from the trnsmission?.. Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 14 Old 03-30-2013
tommays's Avatar
I see learning about quadrants and rudders in your future
There are hundreds of shaft places and if your near any king of boating there should be something local
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #4 of 14 Old 03-30-2013 Thread Starter
Sootydan's Avatar
Removing the shaft coupling from the transmission isn't that bad. Remove the bolts and separate the couplings. But getting the coupling off the shaft is the problem. You can't remove the shaft from the boat without taking off the coupling of course. Using a deep socket etc between the prop shaft and the trans shaft and then tightening down the coupling bolts is one way to get it off but you risk damaging the trans coupling and or the bearing.
so... I can cut the shaft with w 4 inch cutoff wheel on my grinder and then remove the shaft from the boat. remove the bolts holding the shaft coupling to the atomic4 trans coupling and take that out.
Sootydan is offline
post #5 of 14 Old 03-30-2013
JimsCAL's Avatar
I bought a replacement shaft from these guys a few years ago. Very pleased.
Propeller Shafts for sale. Buy your Prop Shaft online and save.
JimsCAL is offline
post #6 of 14 Old 03-30-2013 Thread Starter
Sootydan's Avatar
Hi, Thanks, I've removed the rudder already as usual maintenance. I don't have a quadrant, I'm thinking you have a wheel as opposed to a tiller?
Sootydan is offline
post #7 of 14 Old 03-30-2013
Tartan 27' owner
CalebD's Avatar
Ask other boaters in your area (Gloucester, MA ?) which prop shop they use.
Sometimes it is just a lot easier cutting the shaft in the boat and removing the halves. It was for us 2 years ago. Cut our old bronze shaft with a Sawzall. New SS shaft was @ $250.
Everybody has one:
CalebD is offline
post #8 of 14 Old 03-30-2013 Thread Starter
Sootydan's Avatar
That's what I'm going to do. I was looking for a place to get a new shaft. Thanks
Sootydan is offline
post #9 of 14 Old 03-30-2013 Thread Starter
Sootydan's Avatar
Thanks. Did you send them the old shaft to match up? Mine will be in two pieces after I remove it.
Sootydan is offline
post #10 of 14 Old 03-30-2013
I would try first , before it would get cut , unless the shaft was already junk! A wheel puller is cheaper then a shaft. You people must have more money then brains!....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 12 07-12-2014 06:50 PM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
Prop/Prop-Shaft Key Size? Skipaway Gear & Maintenance 7 07-29-2008 09:04 PM
Prop for Atomic 4 gbeardmore General Discussion (sailing related) 1 05-08-2001 07:27 PM
Prop for Atomic 4 gbeardmore Gear & Maintenance 0 05-03-2001 01:15 PM
