Boom rigging question - Page 2 - SailNet Community
 1Likes
post #11 of 13 Old 04-03-2013
Re: Boom rigging question
... and you'll avoid the chafe on the main leech w/o a topping lift.. however it can be problematic when reefing if there's no way to support the boom when the sail is dropping. That's why you need to spend half a boat buck on a rigid/supporting vang! (you'll have to find a wooden one to match, though )
Congrats on getting her out. Success story for sure.
Faster is offline
post #12 of 13 Old 04-03-2013
Old as Dirt!
svHyLyte's Avatar
Originally Posted by Liquorice View Post
Listen to sabreman - you don't need a topping lift, you already have a main halyard. Use this to keep the boom up when the sail is down.
There's no such thing as a boom stay!
And what, pray tell, will support the boom when (not if) the man needs set a reef while underway?
A topping lift, solid vang that can support the boom/sail or a boom crutch are needed unless one is a true fair weather sailor, non?
svHyLyte is offline
post #13 of 13 Old 04-03-2013
no longer reading SailNet
Alex W's Avatar
It's not only while reefing. What supports the boom when you drop the sail? Dropping the boom into the cockpit isn't very fun, and I don't believe that you can drop the sail and instantly hook the main halyard back to the end of the boom.
I do put my main halyard on the end of the boom afterwords, just to keep it from clanking on the mast.
If you have two main halyards then by all means use one as a topping lift. That's a great setup.
Alex W is offline
Boom rigging Pearson 30 isleofwood P30 4 11-01-2011 08:41 AM
Running rigging for my boom... serenespeed Gear & Maintenance 10 09-14-2010 03:31 PM
Rigging a preventor using the boom vang on a C22 MazeRat7 General Discussion (sailing related) 7 09-02-2009 03:50 PM
rigging inside the boom bestfriend Gear & Maintenance 2 01-08-2007 11:11 PM
