Polishing pulpit and standing rigging - SailNet Community
 1Likes
post #1 of 12 Old 04-01-2013 Thread Starter
first sailed january 2008
northoceanbeach's Avatar
My standing rigging is dirty under where there are covers I protect the jib, so I figured I would polish those an the stanchions and pulpits.
I think I will wash, rub with fine bronze wool and then use flitz polish. I'm not a handyman, so I thought I'd run it by people here because mistake on a boat are costly.
Will this method damage anything or especially hurt the rigging?
northoceanbeach is offline
post #2 of 12 Old 04-01-2013
Morild's Avatar
Re: Polishing pulpit and standing rigging
I can't see that will do any harm at all.
Personally I can polish it just fine, by just using a metal-polish cream, so maybe try with that first?
Btw I replaced all of my standing rigging on my 26" boat last year, it was cheaper than I thought and I think it is a good idea to do if the wires have more than 30 years on them.
Morild is offline
post #3 of 12 Old 04-01-2013
Omatako's Avatar
Personally I would avoid bronze wool if at all possible. The fine scratches left behind will be way more difficult to remove than the loss of shine on the material.
Try a good metal polish first, I use a product called Autosol I think it is a US product so may be available where you are. I use it after a strong acid wash following TIG welding and it shines up really well.
Arthur C. Clarke
Omatako is offline
post #4 of 12 Old 04-01-2013
Morild's Avatar
Good point,
Autosol is the product I use, just couldn't remember the name of it
Morild is offline
post #5 of 12 Old 04-01-2013
Old enough to know better
Flitz should work well also, but I would skip the bronze wool. You might try just using a microfiber cloth with the Flitz on it, that will likely clean it up. Barkeeper's friend works well too, just make sure you rinse it well, as it does contain a light acid.
miatapaul is offline
post #6 of 12 Old 04-01-2013 Thread Starter
How much did it cost to replace your standing rigging? Did you do it yourself?
post #7 of 12 Old 04-01-2013
I'm a big fan of Nevr-Dull, but it works best on stainless tubing, like sanctions and the pulpit. Twisted wire rigging would be messy.
http://www.nevrdull.com/
Jeanneau 54DS
Minnewaska is offline
post #8 of 12 Old 04-01-2013
Why hasn't anyone mentioned "Spotless Stainless" ?
jjablonowski likes this.
mikel1 is offline
post #9 of 12 Old 04-01-2013 Thread Starter
This flitz is actually doing an amazing job. The forestay where I polished glistened like new wire in the sunset. The part I couldn't reach did not.
The boat I just got had these old plastic, somewhat tight fitting plastic covers on the shrouds, with bigger plastic rollers on the bottom. So I cracked and peele them off and will work on the shrouds tomorrow. They have a bit of hmm.. Green fuzz in them tht I will have to brush out.
I wish standing Rigging was an easier job, I would always replace it, but it seems that it and the deck hardware, I.e. the blocks, tackle etc get left the longest. A rope you can replace here or there, but really the standing its all at once.
post #10 of 12 Old 04-02-2013
Morild's Avatar
The new wires were "made" by a rigger, it require special tools to put the terminals on the wires.
I paid around 3.500 DKK (Is 600 USD) for the wires (2 shrouds each side and back-stay) including new turnbuckles! (I hope it's the right Words in English for these Things :-) )
It also gave me the chance to get them shortened a couple of centimeters.
Morild is offline
standing rigging GoodOldBoater North American Yachts 10 04-18-2012 02:21 PM
Standing rigging- Doing it myself irwin325cc Gear & Maintenance 22 06-30-2011 07:32 PM
Standing Rigging Re-do dmkey C22 6 05-23-2010 10:20 AM
Standing rigging katocomb Gear & Maintenance 13 05-21-2007 03:52 PM
Standing Rigging alanporter Gear & Maintenance 6 11-26-2002 09:29 AM
