Adding Hydro Foil to Yamaha 8 HP 4 Stroke on 27 Catalina - Page 3 - SailNet Community
post #21 of 27 Old 04-02-2013
tommays's Avatar
Re: Adding Hydro Foil to Yamaha 8 HP 4 Stroke on 27 Catalina
Having powered the 8000# Cal with a 4Hp outboard during it rescue from the scarp yard i was rather shocked at the amount of stern squat the 4hp was able to produce
Now that its back to normal with a healthy motor and really good propeller
I can put NY NY UNDER WATER at about 6.8 knots
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #22 of 27 Old 04-02-2013 Thread Starter
Is there a way to raise the transom mount up a few inches? or will this not be as strong as the original mount?
mbaillie is offline
post #23 of 27 Old 04-02-2013
no longer reading SailNet
Alex W's Avatar
What speed are you running the motor at?
If you run the motor at full throttle you will not going any faster than half throttle (in light wind conditions), but you will put the motor a lot closer to the water and burn up a lot more fuel.
With a GPS it is easy to figure out what your hull speed is while motoring. Throttle down until you get just below that speed and the boat probably won't squat so much. You'll also get much much better fuel economy (like 2x).
Below hull speed the boat won't squat too much, it'll just go faster. Above hull speed more throttle will just make the boat squat more, but it won't go any faster.
Reserve higher throttle for quick acceleration, deceleration, and pushing with the motor into a high head wind.
Alex W is offline
post #24 of 27 Old 04-02-2013
It's certainly possible to raise the threshold of the motor mount, but you probably won't be able to tilt the motor free without enlarging the cutout.. and you'll raise the prop wrt the waterline, reducing performance in any kind of chop.(or need a longer shaft still)
I think you'll find if you back off the throttle you'll be moving fine with less squat and saving on fuel besides....
Faster is online now
post #25 of 27 Old 04-02-2013 Thread Starter
I will give that a try and see what speed im going with less throttle.
thanks everyone. Any other advice please keep posting. Sail net is a great information tool.
mbaillie is offline
post #26 of 27 Old 04-02-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
that is the "trouble" with displacement hulls.. the faster you go, the more water you displace.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #27 of 27 Old 04-03-2013
I had a fin on my 16 foot heavy fishing boat. When it was rough, planeing speed was too fast. At about 10 to15 MPH, without the fin the bow would be way up in the air, making it hard to see. The fin solved the problem completely, the bow would stay down at any speed. Not sure how it would work on a displacement hull? One way is to try it, they are not very expensive.
Paul T
dabnis is offline
Tags
catalina 27 , drowning motor , hydrofoil , se sport , stingray
best tiller extension for a 15 hp Yamaha 4 stroke mcglinn General Discussion (sailing related) 1 07-20-2010 06:38 AM
Yamaha 2.5 4 stroke issues chucklesR Gear & Maintenance 31 08-08-2008 08:54 PM
Yamaha 9.9hp 4-stroke WagTheDog Gear & Maintenance 7 04-23-2008 10:32 AM
Need Yamaha 15 HP 2-stroke help/advice coreywoodworking Gear & Maintenance 4 02-29-2008 01:21 PM
Yamaha 4 stroke Ozsail Gear & Maintenance 1 06-05-2002 01:32 AM
