06-18-2004
Vibration dilemma
When I replaced my two bladed prop with a three blade, I got a noticeable vibration at low speeds which disappeared at higher revs. Finally found that shaft struts were at exactly 120 degrees to each other, so blanketed two blades simultaneously three times each rev. Yard cut off struts near hull, welded plate across remaining stubs, and to that welded new vee struts at smaller angle. Worked fine.
