Proper Way to Secure Horseshoe Buoy - SailNet Community
 6Likes
post #1 of 27 Old 04-04-2013 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
What is the proper way to secure a horseshoe buoy in its cradle? Do you just leave it loose? Seems like it would blow away. Do you clip it to the cage? Seems like that would prevent you from throwing it quickly.
Jim Buoy Horseshoe Buoy
Jim Buoy Standard Size Horseshoe Buoy
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #2 of 27 Old 04-04-2013
Junior member, rest old
msmith10's Avatar
Re: Proper Way to Secure Horseshoe Buoy
I leave it in the cradle but don't strap it in. In case I'm the one who goes overboard, I don't want some knucklehead panicking because they can't get it out of the cradle.
I've never lost one.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 27 Old 04-04-2013
Senior Moment Member
SloopJonB's Avatar
First of all, replace it with a ring. Horseshoe buoys aren't even legal flotation devices in Canada. Rings throw better, work better and in my experience stay good looking a lot longer.
SloopJonB is offline
post #4 of 27 Old 04-04-2013
We've lost a horseshoe buoy on a windy day--and found it, more than an hour later, by returning a little "downcurrent" along our GPS track and keeping a sharp eye out.
I now secure it loosely with a small velcro cable tie around the pushpit so it's tight enough to stay on the boat but not so tight that it can't be yanked off the bracket should we ever need it.
zeilfanaat is offline
post #5 of 27 Old 04-04-2013
msmith10's Avatar
I agree with JonB. I switched to a ring years ago. That's my "immediate deployment" device, followed by a lifesling.
Mark Smith
msmith10 is offline
post #6 of 27 Old 04-04-2013
Stu Jackson's Avatar
After our first buoy disintegrated in the sun, my wife got smart: we simply leave it down below when not sailing or singlehanding. Betcha it's gonna last a LOT longer.
msmith10 likes this.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #7 of 27 Old 04-04-2013
A big velcro strap wrapped once around the buoy and whatever it is hanging from. Or, since we had bungee but no spare velcro at hand, a loop of bungee cord with a toggle on it. Loop the bungee all the way around and over the toggle.
Either one can be released pretty quickly, and the bungee is easier to slash if you've got a knife handy.
If you're out in really nasty weather you may want to add one or two more ties lower down, since a buoy that has washed away is totally worthless. But I'd leave that as part of the heavy weather prep--not everyday.
hellosailor is offline
post #8 of 27 Old 04-04-2013
tommays's Avatar
Its been hanging without issue and attached to a good size heaving line in the bag so you throw it and retrieve if needed
It takes a few seconds to keep it below
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 27 Old 04-04-2013
Tether it to your MOB pole. When you release the pole it should take the buoy with it. Although they're pricey, around here the MOM-8 appears to be replacing the horseshoe/pole combo. Switlik - MOM 8-A - Sailing Man Overboard Safety
Hudsonian is offline
post #10 of 27 Old 04-04-2013
That's what we went to. Not only much easier to deploy, but the inflatable pole is the only likely way to find whomever went overboard. Particularly for us, as we often double. If one of us is in the drink, the other will have to take their eye off them to get the boat turned around.
Just bought it a couple of years ago and I think its due this year for recertification. I wonder what that is going to cost. Suspect its a doozy.
We run the clip strap for the horseshoe under the pushpit rail and back, so it can't blow away. Would not be a great idea, if not for the MOM.
Jeanneau 54DS
Minnewaska is offline
Lifesling or Horseshoe for MOB mm2187 General Discussion (sailing related) 35 12-16-2012 08:58 PM
Horseshoe Kalmia41 Gear & Maintenance 10 12-30-2006 01:14 PM
Horseshoe rescue bouy.. groundhog Seamanship & Navigation 20 10-01-2006 03:10 PM
Horseshoe on rope? Cony Gear & Maintenance 5 02-16-2004 03:32 PM
