Mounting electronics on a pedestal guard - SailNet Community
 4Likes
post #1 of 14 Old 04-04-2013 Thread Starter
I am looking for a simple and inexpensive way to mount a Garmin 541S to my pedestal guard on my Endeavour 32. I have looked at some of the Edson mounts, and they quite pricey. Any ideas would be appiiciated.
algee is offline
post #2 of 14 Old 04-04-2013
Re: Mounting electronics on a pedestal guard
My Newport 30 has an Edson wheel and the stainless tube guard. When I first installed my 541S I built a pair of aluminum brackets and clamped them to the uprights ahead of the compass. The compass failed from seawater intrusion, (heavy sigh), so I bought a bulkhead compass and build a flat plate that fits atop the pedestal where the compass used to be and it provides a base for the Garmin mounting bracket that came in the box. The GPS is better-protected by the guard and it's easier to keep an eye on the screen. The stock bracket also provides easier tilt and pan so I can watch the screen from any position when I'm at the wheel. I can easily watch the compass in it's new location, too.
guyfromiowa is offline
post #3 of 14 Old 04-04-2013
Maine Sail's Avatar
I designed this mount a couple of years ago.. A small piece of Starboard with two 1" holes in it lined up for the guard centers, four 316 SS clamp collars from McMaster Carr and you're done. Simple and looks factory made... I do polish the clamp collars with a grinder mounted cotton buff wheel and Tripoli compound first....
copacabana, tommays and SloopJonB like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 14 Old 04-04-2013
Asleep at the wheel
jimgo's Avatar
That's pretty cool! Nice job!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #5 of 14 Old 04-04-2013
no longer reading SailNet
Alex W's Avatar
Check used marine stores (or eBay) for NavPod's that you can modify to fit your unit. In Seattle Second Wave has a selection of them, some cheap, some expensive, and it's often random which is which. I've even seen unused ones cut out for a specific unit.
I like Maine Sail's approach, though it would get messy if it were a unit with more than one cable (my e7D has 3 cables). Those clamps are also $32/ea, so it's a bit cheaper than a cut to fit NavPod, but not hundreds cheaper.
I do wish there were some cheaper options.
Alex W is offline
post #6 of 14 Old 04-04-2013
Junior member, rest old
msmith10's Avatar
I bought one of the Snapit things at West, mounted the swivel base that came with my Garmin to that, and mounted the Snapit on the pedestal guard. Cost about $20, looks good and has lasted for years.
Has added benefit of being able to swivel to any direction, so I can see my plotter no matter where I am in the cockpit.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #7 of 14 Old 04-05-2013
I bought a stearboard cup holder that mounts to the tubing. Then removed the top cup ring and mounted my handhealed gps to the flat base. Works great. Did the ICW from the c &d to miami no problems
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
post #8 of 14 Old 04-05-2013
These folks make universal mounts for countless things. You'll have to dig around to see if they have an adapter for what you are trying to mount, but they will have something to connect it to the pedestal.
http://www.rammount.com/
Jeanneau 54DS
Minnewaska is offline
post #9 of 14 Old 04-05-2013 Thread Starter
You guys are the best!! I just ordered a mount from SNAPIT, and I think it will work great. Thanks for the help.
algee is offline
post #10 of 14 Old 04-05-2013
BarryL's Avatar
RAM Mounting Systems, Inc.
You beat me to it! Rammount stuff is really great and they have adapters for EVERYTHING.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
Using a Pedestal Guard, Edisonís Vision for Electronics southwindphoto Electronics 1 07-26-2010 10:59 AM
Wiring through pedestal guard downeast450 Gear & Maintenance 19 03-16-2010 10:51 AM
Show me your pedestal mounted electronics hazmat17 Gear & Maintenance 8 02-24-2010 03:42 PM
mounting nav desk electronics janders Gear & Maintenance 16 03-05-2009 11:30 AM
Wiring GPS: pedestal or pedestal guard? geary126 Gear & Maintenance 14 05-17-2007 02:43 PM
