cleaning up after our fine feathered friends - SailNet Community
 1Likes
post #1 of 12 Old 04-05-2013 Thread Starter
I was hoping some knew a good way to cleanup after birds decided to roost on spreaders I have tried boat soap and a cleaning spray niether have worked to the standard i wanted still see the white marks on my blue deck
I was wonder what worked for others
jhgreen is offline
post #2 of 12 Old 04-05-2013
Re: cleaning up after our fine feathered friends
I have a horrendous barn swallow problem and my boat is carpet bombed daily. I have used soft scrub with bleach on my white deck with good results. Then i wax the hell out of it to keep it clean.
Next step is to hire mercenaries with shot guns.
benesailor is offline
post #3 of 12 Old 04-05-2013
Running some small SS seizing wire or monofilament between upper shroud(s) and mast a couple of inches above the spreaders should discourage the 'roosting' and reduce the cleaning requirement...
Faster is offline
post #4 of 12 Old 04-05-2013
Asleep at the wheel
jimgo's Avatar
I'm told plastic owls work well, but you need to move them around periodically or the birds learn that they aren't real.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #5 of 12 Old 04-05-2013
Seen those fake owls covered in bird poop.... but sometimes they miss
Rubber snakes are also touted as effective, but I doubt they would deter a seagull at 30 feet...
I've seen a string full of CDrom discs hung above the sailcover to try to keep them clean too.. probably works for roosting but not air drops...
Faster is offline
post #6 of 12 Old 04-05-2013
tommays's Avatar
I am installing a raw water wash-down pump as we speak as Northport is near a large Seabird nesting area and NOTHING STOPS them in season
Its mind boggling what they can do to a boat they really take a liking to
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 12 Old 04-05-2013
rhr1956's Avatar
Based where they seem to like to poop on my boat (my blue sail cover) I would recommend painting the deck white. It's the BLUE color they targeting!
rhr1956 is offline
post #8 of 12 Old 04-05-2013 Thread Starter
Thanks for the ideas i just got new blue sail covers because my green one were destroyed
jhgreen is offline
post #9 of 12 Old 04-05-2013
CapnChuck's Avatar
We tried every conceivable method of keeping birds away and nothing worked. We finally gave up and covered all of the sunbrella with cheap plastic tarps to protect them. We had one bimini completely ruined. Chuck
Our Blogs
CapnChuck is offline
post #10 of 12 Old 04-05-2013
To clean the sh!t try Poop-off. Sold in pet supply stores to clean bird cages. Really works.
kellysails likes this.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
ereiss is offline
A sad end for a fine boat PaulinVictoria C & C 31 08-22-2014 10:56 PM
The boat'll be fine, right?? jppp General Discussion (sailing related) 9 08-28-2011 01:07 PM
Another fine day cormeum General Discussion (sailing related) 2 10-07-2009 02:46 PM
Do friends let friends buy a Newport 33' redmans Boat Review and Purchase Forum 5 05-15-2009 01:08 PM
