Standing rigging longetivity - Page 2 - SailNet Community
 1Likes
post #11 of 18 Old 04-07-2013
blt2ski's Avatar
Re: Standing rigging longetivity
You have probably at lest two, if not three or four places within 1/2 mile and walking distance of where you keep your boat that should be able to help you with ALL the materials, along with doing the parts you do not want to do. "Port Townsend rigging" IIRC is on the NW corner entry of your marina/boatyard you are at. WM is 1/4 mile east with parts. They can send stuff to or get the seattle store which has a rigging shop to do things. Brian Toss is in the marina to the far east....$$$$$$$$$. I believe there are one or two others that should also be able to help, get you parts etc too.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #12 of 18 Old 04-08-2013
Depends on what kind of life it has had. Ten years is short for a boat which sat in a marina with zero salt or motion on its rig. For that kind of use, ten years is a riggers scam .It's a totally different matter for a boat crossing oceans, where it will get far more abuse and potential fatigue in one month.
Brent Swain is offline
post #13 of 18 Old 04-09-2013
casey1999's Avatar
Suggest pulling the chain plates and inspecting, replace bolts with new. Replace chain plates if needed.
casey1999 is offline
post #14 of 18 Old 04-09-2013
casey1999's Avatar
Question:
I am also looking at installing new standing rigging. Plan to do one at a time. Concerned about replacing the shrounds and fore and back stay.
Can I depend on a haylard to hold the mast up while I am at the top of the spar? Would you rig more than one halyard, one as a back up? Have you ever lowered your entire forestay (including a furler unit) with the mast still up? Would be a lot easier to take the mast down, but at my location there are not facilities to easily do this.
Also, if you have a shroud, fore, or aft stay fail at sea, how do you climb the mast to repair? I would be a little concerned depending on a haylard to hold a swaying mast in big ocean swell with me at the top of the mast.
post #15 of 18 Old 04-09-2013
Yes, halyards work well for replacing one shroud at a time.
post #16 of 18 Old 04-09-2013
casey1999's Avatar
Normal shroud tension is say about 15% of your wire breaking strength. For my 5/16 316 wire that is about 1,500 lbs.
How much tension should I have on a haylard before I climb the mast? Realize on is just trying to stabilize the mast so are we talking a 100 - 200 lbs?
post #17 of 18 Old 04-09-2013
fallard's Avatar
I had my 22 yr. old rod rigging replaced last year with the boat in the water. The photo shows the professional riggers doing the job at my shallow water dock
Just to complete this picture, my swing keel is fully retracted to clear the bottom (2.5 ft at MLW):
They used my halyards and had no problem. The form stability of the boat is all that matters in this situation, as well as having the halyards secured. As a safety matter you shouldn't rely on the self-tailer on a winch to prevent the halyard from running free. ALWAYS tie the bitter end off with minimum slack.
fallard is online now
post #18 of 18 Old 04-09-2013
KNOT KNOWN
Capt.aaron's Avatar
When I worked as a professional rigger in Miami, I spent many hours a week in a chair up a mast, changing out wires, with a halyard in their place. Make sure you use a halyard that is run through a sheeve and not one hanging on a block. And make sure you go up on one that is also running through a sheeve as well. Make sure the halyards are in new condition.
casey1999 likes this.
" Some are boat wise and some are other wise"
Capt.aaron is offline
standing rigging GoodOldBoater North American Yachts 10 04-18-2012 03:21 PM
no standing rigging? timangiel General Discussion (sailing related) 13 07-18-2011 09:56 AM
Standing rigging katocomb Gear & Maintenance 13 05-21-2007 04:52 PM
Standing Rigging alanporter Gear & Maintenance 6 11-26-2002 10:29 AM
Standing Rigging docsabre Gear & Maintenance 2 05-18-2002 05:48 AM
