Sealing through hulls in balsa cored boat - SailNet Community
 1Likes
post #1 of 16 Old 04-05-2013 Thread Starter
Ive recently purchased a dreadnought 32 with a balsa cored hull. There are two gate valves in the head that are fairly corroded and have me a bit concerned. Im planning to haul to boat out and remove these Valves as well as glass over the thru hulls. My reserach has found that a 12-1 taper is to be ground into the edge of the thru hull in order to prepare it for glassing. My question is how to put this taper into the holes when there less than a foot apart and if its a differnt proccess to glass over a through hull thats into a balsa core. Ive done a bit of deck repair already with polyesther resin. but nothing under the waterline like this. I want to make sure I do the best job possible so any advise anyone could give me on what materials to use and how to go about it would be a great help. Thank you much.
liveitwell is offline
post #2 of 16 Old 04-06-2013
Re: Sealing through hulls in balsa cored boat
LiveIt,
The 12:1 is probably referring to the thickness of the fiberglass so if it's 1/4" thick, taper it 12/4 or 3" to each side. This allows the application of a series of circles of fiberglass that increase in size each sequential layer until they reach full size. Before you do this, plug the balsa hole with filler and be sure to taper both inside and outside holes properly.
DonScribner is offline
post #3 of 16 Old 04-09-2013
I don't discuss my member
zz4gta's Avatar
liveitwell, grind out your 12:1 the best you can with the room you have. If you want you can even sand down that stringer (just enough to get the paint off) and put a piece of cloth that overlaps that. Basically, the 12:1 is best case senerio. I only had a 6" diameter area to work with a hole that was 3/4"-1" thick, so my bevel turned out to be 6:1 roughly. 4 years and countless waves, and it doesn't leak a drop. I just beveled it from the inside.
I understand what the book says and why it says it, but sometimes you have to do the best you can w/ what you got.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #4 of 16 Old 04-09-2013
Junior member, rest old
msmith10's Avatar
The core should be handled like you would a penetration of the deck core: take the coring back between the glass layers, seal the coring edges with thin epoxy, then replace the coring with thickened epoxy. Now glass over.
There's a good illustration of this here: http://www.wbryant.com/StellaBoat/index.htm
Go to the "Haulouts" tab.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #5 of 16 Old 04-09-2013
Tartan 27' owner
CalebD's Avatar
I'd use epoxy as it has better adhesive qualities than polyester.
You may find this article useful: Sealing Deck Penetrations to Prevent Core Rot Photo Gallery by Compass Marine at pbase.com
Everybody has one:
CalebD is offline
post #6 of 16 Old 04-10-2013
Hi
West Systems has great online resources (and many mentions of cases like yours)
Forum wont let me post url -- but go to westsystem.com / ss / use-guides
whippet99 is offline
post #7 of 16 Old 04-10-2013
Go to epoxyworks.com for comprehensive answers to this question. Then: Articles by subject; Boat repairs and restoration;Repairing machined holes in fiberglass. Epoxyworks is a West pubblication.
Hudsonian is offline
post #8 of 16 Old 04-10-2013 Thread Starter
Thanks for the info folks, keep it coming its a great help! Ive got a better idea of how to go about it now. Ive also been doing lots of tapping to try and detect any delamination, tricky below the waterline. Seems like it might not be as bad as I imagined, though i can be an optimist... Any more info is welcome you folks are great, thank you.
post #9 of 16 Old 04-10-2013
Liquorice's Avatar
I may be completely out to lunch here - , but the engineer in me says the 12:1 should be on the outside!
Logic tells me the pressure is pushing outside ->in when the boat is in the water. So shouldn't the wedge be on the outside so water pressure tends to hold the plug in place more firmly?
Never done this, but that would be my first thought.
Sam :-)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
post #10 of 16 Old 04-10-2013
msmith10's Avatar
Sam :-)
Hopefully you're not relying on water pressure to hold anything in place. The 12:1 feather is to get good bonding of the new glass to the old, so you want it on both interior and exterior.
Mark Smith
msmith10 is offline
Balsa Cored hull Bardo Boat Review and Purchase Forum 44 10-09-2016 11:24 PM
1980's Sabre balsa cored hulls grande4 Boat Review and Purchase Forum 23 10-08-2014 12:42 PM
Balsa cored hulls bjung Sailboat Design and Construction 27 02-11-2013 03:41 PM
Which C&C sailboats have balsa cored hull? alexsails Boat Review and Purchase Forum 26 06-08-2010 05:51 AM
Balsa cored hulls - old boats gstraub Boat Review and Purchase Forum 20 02-21-2003 05:08 PM
