Blogs
User Name
Old 05-27-2004
hamiam hamiam is offline
hamiam is on a distinguished road
Towing a RIB
I recently purchased an Aria 10'' RIB made by AB. Unlike my Zodiac which had a total of 3 tow rings on the bow (one in the dead center and one off to either side) she only has a single tow ring in the center that is anchored to the hull. Any tips for towing her? With The Zodiac I would use 2 long docklines, criss-cross them and cleat them to separate cleats near the stern. This way I could control where she tracked. Perhaps the RIB will track better given the solid hull and its shape. Any thoughts would be appreciated.
Old 05-28-2004
Sailmc Sailmc is offline
Sailmc is on a distinguished road
Towing a RIB
The ring on the bow is generally not used for towing. You need one ring on either side of the bow to tow properly. I''ve never seen a dingy without these. You should consider installing them or having them installed. I doubt you will be able to make the present set up work satisfactorally
Old 05-28-2004
Towing a RIB
Thanks, I called the company and they gladly offered to sell me the necessary d-rings. What a joke. Im pissed. What idiots make an inflatable without towing rings. I wish I had noticed that before as this really puts a kink in our weekend plans.
Old 06-01-2004
takwita takwita is offline
takwita is on a distinguished road
Towing a RIB
I have had a Carib 10X RIB for almost 10 years. The bow eye works great for towing. Inspect it now and then..If its well built you should have no problem.
BTW : my friend has the same RIB and he glued the D-rings on. No difference in towing ability.
I also attach a safety line very loosely to one of the davit eyes just in case the line lets go when towing in open water
Old 06-13-2004
drhea drhea is offline
drhea is on a distinguished road
Towing a RIB
I have a 16ft zodiac w/ 50HP outboard and have towed it weekly for 7 years with only the bow eye. I tow with a fairly short floating tow line, and run a second line from a cleat on the tender''s bow. The second line is a good back up, and it also keeps the bow down in waves. It tracks fine. I haven''t towed in more than 6 foot seas, nor would I recommend it.
I learned the hard way about the second line, noticing a tender that looked a lot like mine a mile away with no one on it -- and in the busy shipping channel. hummmmm. What fool.....?
Old 06-14-2004
Towing a RIB
I have not tried to tow her from the bow ring but i was told 2 things; 1. that the bow ring lacks the strength necessary and will rip out and 2. that she will no track well using the one attachment point. I guess i can try it out and see what happens.
Display Modes
vB code is On
Anchor Question Result Dzedzej Seamanship 24 11-16-2006 06:56 PM
Towing a dingy in chop sailr4 Seamanship 7 12-29-2004 02:06 PM
Towing an Ericson ''27 kspitler General Discussion (sailing related) 2 08-31-2003 05:10 PM
Towing hard dinghy EClaire Gear & Maintenance 3 04-24-2003 08:47 PM
Towing your dingy RobGallagher Gear & Maintenance 2 03-21-2002 11:37 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
