Mildew in the Cabin - Page 2 - SailNet Community
 6Likes
post #11 of 23 Old 04-07-2013
chef2sail's Avatar
Re: Mildew in the Cabin
Im with the Chef, Kanaberra Gel. Since using it starting 3 years agvo not one drop of mildew. I thin Minniewaska will also agree with this also.
Dave
T37Chef and Minnewaska like this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #12 of 23 Old 04-07-2013
Wayne25's Avatar
Bounce dryer sheets in storage compartments and under the cushions.
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
post #13 of 23 Old 04-07-2013 Thread Starter
pdqaltair's Avatar
Originally Posted by capecodda View Post
One winter storage cheap solution is kitty litter in buckets or pans (the more surface area the better) in all the cabins. Even sealed up the boat can start the season with no mildew to cleanup. We also remove all fabrics, cushions, etc.
But you may be driving for solutions that work while commissioned, we haven't had much problem with that up here.
Just driving for ideas worth testing side-by-side, and many have been offered. Good.
Kitty litter works by buffering the humidity and keeping it stable. We tested the silica gel type and found it to be the most economical product of it's type. An hour in the oven at 250F gets it ready for re-use, year after year.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #14 of 23 Old 04-08-2013
For winter storage,
I strip all the cushions and any soft goods off the boat, I have racks at home in the basement for everything.
Keep water out of the bilge.. with the mast down it's not a problem, with the mast up, I get some water intrusion into the bilge. I have a bolt that I can remove in my bilge that allows the most of the water to run out through the centerboard trunk. I pump out any residual every couple of weeks and air the boat out.
after stipping everything, I've been applying lemon oil to the bare surfaces. I leave all the drawers and lockers open, remove the floorboards etc. So far, so good.
In season, It hasn't been an issue.
I'll look into the kanberra gels, and sprays.
tempest is offline
post #15 of 23 Old 04-08-2013
Dave
Yup, started a thread on this stuff a few years back when I first heard of it. I reload twice a year now. Just ordered the spring supply.
I'm not sure it will kill a runaway colony that got a head start, but it does a nice job of keeping it from coming back. They make a spray now, I wonder how that works for cleaning? I've found, for it to work best, you need to limit air exchange for a period of time.
The active ingredient is tea tree oil and the manufacturer explains why theirs is worth the month. Here's the link to the thread here:
Kanberra gel
Jeanneau 54DS
Minnewaska is offline
post #16 of 23 Old 04-08-2013
snake charmer, cat herder
zeehag's Avatar
i clean my boat with vinegar without any problem of smelling like vinegar--which, btw, is a lot better than dying of black mold.....
mold in material is the key to dispo-ing that material as the fabric will disintigrate from the mold and mildew.
pricey chemicals labelled anti mold anti mildew are very harsh on asthmatic lungs....not to mention the short term only capoacity for killing mold--they do not address spores. vinegar changes pH to acid and the spores do not grow in acid.
formosa 41, cruising tropics
zeehag is offline
post #17 of 23 Old 04-08-2013
One
Always tired
Originally Posted by marcusc130 View Post
It smells like vinegar..... Forever.
Yes, and just when you think it stops smelling, it gets just a little bit moist or wet, and there it is again.
One is offline
post #18 of 23 Old 04-08-2013
Asleep at the wheel
jimgo's Avatar
I think the key here is that PS is trying to find solutions for mold on fabrics in the cabin, while I think many of us have focused on mold that is on headliners or on the hull. I've had success in using a combination of vinegar and tea tree oil, along with a Mr. Clean Magic Eraser (or the knock-offs of those). You just have to remember to shake the vinegar and oil, otherwise you wind up only spraying the vinegar. As mentioned elsewhere, the vinegar changes the pH, so the mold can't grow, and the tea tree oil kills the mold.
Now, ridding yourself of the mold stains, that's another story entirely!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #19 of 23 Old 04-08-2013
no longer reading SailNet
Alex W's Avatar
The big thing for me was finding the source of moisture in my boat. I had a persistent small puddle of water on the floor of the head that took me months to track down. It turned out to be a very slow leak in one of the hot water heater lines that would drip a bit as long as the system was pressurized.
Once I fixed that I got a very dry boat and mildew stopped being an issue.
I did wipe down all of my hard surfaces with a tea-tree oil containing spray. I mixed in another ounce of pure tea tree oil (not cheap stuff) to make it stronger. I like how tea tree oil smells, so it at least made the boat smell nicely and killed existing mildew, but I can't say if it did anything about new mildew.
We do sail it about once a week, that helps.
Alex W is offline
post #20 of 23 Old 04-08-2013
Ewh, moldy fabric.
Washing machine, hot water, repeat every couple weeks?
Seriously, I'd bet spraying it with colloidal silver solution would work. Or tea tree oil, or any of the other antifungals. With porous natural fabrics, crud is supposed to infest them in a damp environment.
If you've ever sniffed tea tree oil right out of the bottle, I'm not sure that having it disperse to be breathed in a closed space is a great idea. We all do worse but still, it is an irritant.
What I can't figure is how Kanberra can sell it as a bio-active product (mildecide, fungicide) without getting flack from the EPA, who genearlly get upset about any claims like that without an EPA certification attached. Maybe because it is "organic" ?
One likes this.
hellosailor is offline
Gelcoat Mildew-I'm so sick of gelcoat mildew bwindrope Gear & Maintenance 45 11-15-2015 04:28 PM
mildew neophyte2006 Boat Review and Purchase Forum 12 11-29-2009 09:27 PM
Mildew wind_magic General Discussion (sailing related) 13 05-27-2008 05:28 AM
fastening to cabin fiberglass cabin interior marcusn Gear & Maintenance 3 09-06-2007 07:04 PM
mildew prevention BrianConley Gear & Maintenance 2 10-25-2001 09:13 AM
