Aluminum screws instead of stainless - Page 2 - SailNet Community
 3Likes
post #11 of 22 Old 04-08-2013
overbored's Avatar
Re: Aluminum screws instead of stainless
the aluminum will suffer more. the ti will not corrode but the aluminum will do all the corroding. much cheaper to replace bolts then an alum mast
How is it easier to isolate? the bolts are the exact same dimensions and function exactly the same
"GOLD RUSH" PRINDLE 16
overbored is offline
post #12 of 22 Old 04-08-2013
One
Always tired
They don't tend to work as well as an electrode as steel does. And as for same size: Why would you use the same size? On second thought, don't answer that, because:
In any case, that wasn't the point. The point was that surgical screws, nuts and bolts aren't exactly needed in a marine setting.
One is offline
post #13 of 22 Old 04-08-2013
overbored's Avatar
but that is the point of the galvanic series, they make a better electrode then stainless with regards to aluminum. they will eat away at the aluminum better then the stainless. and are not needed in the marine environment unless you have a carbon parts on your boat
post #14 of 22 Old 04-08-2013
Overboard,
Titanium is higher on the galvanic chart, but it has the advantage that when exposed to air or water titanium instantly creates a titanium oxide coating that is an insulater. So that a titanium-aluminium joint has a lot of galvanic potential, but very little current. Simply because the resistance is so high.
I DO NOT recommend installing titanium directly onto other metals without insulation, but I can point you to a few studies that found that a titanium-stainless joint actually corrodes slower than a stainless-stainless joint. Because of the insulating properties of titanium.
And as for cost... Somewhere between the cost of 316L and siliconized bronze fasteners typically. Specialty fasteners can vary widely though.
One likes this.
Greg
Stumble is offline
post #15 of 22 Old 04-08-2013
One
Always tired
Carbon is even more prone to corroding everything.
However, even if it's higher on the galvanic scale (for pure titanium), there are different titanium alloys, and it still doesn't work as an electrode to the same degree as a stainless piece of metal. I think it's to do with it being a piss-poor conductor, even if caked with salt and therefore moisture.
One is offline
post #16 of 22 Old 04-08-2013
One
Always tired
Hmm, yeah, as I said ...
Edit: Sorry, I thought i responded to Overbored.
One is offline
post #17 of 22 Old 04-08-2013
baDumbumbum
bobmcgov's Avatar
Also, aluminum has dreadful fatigue and work hardening properties. A threaded aluminum fastener would develop stress risers and fail very, very quickly. Even the threads themselves are prone to work hardening under cyclical loads, then stripping catastrophically. Had an air compressor head blow right across the shop that way. FWIW, I'm not keen on tapping any fasteners into aluminum spars for that reason, not if they see tensile loads. Thru bolting makes me happier.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #18 of 22 Old 04-08-2013
How about Monel rivets?
MarkSF is offline
post #19 of 22 Old 04-08-2013
Monel sits just below titanium on the galvanic chart (so it is slightly less anodic depending in general) but close enough that you have to look at exacally what alloy. For aluminium applications Monel is worse than stainless at causing galvanic corrosion.
It is also more expensive ( often more expensive than titanium)
Very heavy
And hard to machine. Monel rivets would be a pain to instal without power tools.
Greg
Stumble is offline
post #20 of 22 Old 04-08-2013
I went ahead and pulled the article I referenced above. This is a pear reviewed study from NIH investigation surgical implants which live in a more corrosive environment than even our boats. It's warm, wet, and salty all the time. But there is enough free oxygen to allow for self healing metals (like titanium and stainless) to operate.
Is galvanic corrosion between titanium alloy... [Spine J. 2004 Jul-Aug] - PubMed - NCBI
And some other experts in the field:
http://www.corrosionist.com/Galvanic..._Titanium.html
http://www.sciencedirect.com/science...11916401004350
One likes this.
Greg
Stumble is offline
Stainless -vs- Aluminum Cookware hriehl1 Gear & Maintenance 45 03-07-2014 02:38 PM
Stainless screws into aluminum Kiltmadoc Gear & Maintenance 23 01-01-2013 06:10 PM
aluminum or stainless rivets? caver504 SailNet FAQ 8 10-07-2010 07:14 PM
Aluminum vs. Stainless cleats bwindrope Gear & Maintenance 11 04-29-2009 05:10 PM
Turnbuckles - Stainless versus Aluminum Finallybuyingaboat Gear & Maintenance 9 10-05-2007 09:47 PM
