Aluminum screws instead of stainless - Page 3 - SailNet Community
 3Likes
post #21 of 22 Old 04-08-2013
overbored's Avatar
Re: Aluminum screws instead of stainless
Originally Posted by MarkSF View Post
How about Monel rivets?
Monel grade 50 cherry rivets ( blind or pop rivets ) are use in aircraft some times on aluminum because they are lower on the Galvanic chart then the SS grade 51 cherry rivets but they are not a strong as the SS grade 51's in both shear and tensile strength
"GOLD RUSH" PRINDLE 16
overbored is online now
post #22 of 22 Old 04-08-2013
tommays's Avatar
And outboard motor goes through hell and something as simple as a coating of PERFECT SEAL GASKET SEALER is more than enough to make a saltwater lower unit pretty easy to take apart on the next service
If you look at BIG OUTBOARDS were there is plenty of money one of the solutions used by the OEMs who know a bit is chrome plated SS bolts
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Stainless -vs- Aluminum Cookware hriehl1 Gear & Maintenance 45 03-07-2014 02:38 PM
Stainless screws into aluminum Kiltmadoc Gear & Maintenance 23 01-01-2013 06:10 PM
aluminum or stainless rivets? caver504 SailNet FAQ 8 10-07-2010 07:14 PM
Aluminum vs. Stainless cleats bwindrope Gear & Maintenance 11 04-29-2009 05:10 PM
Turnbuckles - Stainless versus Aluminum Finallybuyingaboat Gear & Maintenance 9 10-05-2007 09:47 PM
