Aluminum screws instead of stainless - SailNet Community
 3Likes
post #1 of 22 Old 04-07-2013 Thread Starter
Considering that stainless screws into aluminum will corrode in spite of using Tefzel gel (the gel will eventually wash out). Why not use aluminum screws?
Frogwatch is offline
post #2 of 22 Old 04-07-2013
norahs arc's Avatar
Re: Aluminum screws instead of stainless
Aluminum screws are not very strong. They may be alright for fastening trim but for anything else the are likely to fail.
One likes this.
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
post #3 of 22 Old 04-07-2013
Aluminum screws should actually work fine. 6061-T6 has a min yield of 35ksi compared to 316 stainless steel with a yield of 45ksi. That means that a 3/8" machine screw of 6061-T6 will handle 3864 pounds before deforming permanently where the stainless can go to 4968 pounds. Yes, there is a difference, but is the aluminum screw already overkill? That's something that you'd have to decide. Is the decrease in strength worth the decrease corrosion? But . . . have you pulled any two aluminum components apart lately? I pulled my gooseneck out of the boom and found gobs of corrosion inside. Quite frankly, regardless of the numbers, stainless is still probably the best answer. New technologies aside, sometimes the old ways are the best ways, tried and true.
DonScribner is offline
post #4 of 22 Old 04-07-2013
no longer reading SailNet
Alex W's Avatar
You are correct that the yield strengths are in the same ballpark, but the tensile strength of 316 is 90kpsi, compared to 42kpsi for 6061-t6.
Alex W is offline
post #5 of 22 Old 04-07-2013 Thread Starter
Looking over the galvanic series, Aluminum bronze looks good.........until you try to find any fasteners made from it. There are a couple of companies in India selling them. There must be something better than SS.
post #6 of 22 Old 04-08-2013
Old as Dirt!
svHyLyte's Avatar
Screws function in either tension or shear--i.e. "pull" along the center axis of the screw or, in shear, pull-push across with width of the screw. On a mast, almost all fasteners are loaded primarily in shear although mast mounted winches subject their lower fasteners to both shear and tension. Aluminum is relatively poor in tension, compared with a similar sized ss screw, and much poorer in shear. That said, one can certainly size aluminum screws for the loads they are likely to be subjected to although the fasteners will be proportionally larger and, being used less frequently, more difficult to find and costly. Being treated with TefGel, or Lanacote for that matter, and properly bedded to prevent water infiltration into the threads will prevent or limit the corrosion problem.
svHyLyte is offline
post #7 of 22 Old 04-08-2013
An aside...thought I had an inside track on some very light, very strong screws when
my son was home sorting out some Titanium screws used in spine surgery...until he
explained each screw sold for many hundreds of dollars!
HUGOSALT is offline
post #8 of 22 Old 04-08-2013
One
Always tired
Well, you can get non-surgical titanium bolts, screws and nuts for much less - (track) motorcycle tweakers use them a lot.
Hell, you can even get carbon fiber bolts and nuts (yes, really).
One is offline
post #9 of 22 Old 04-08-2013
overbored's Avatar
except that titanium is worst then stainless on the galvanic series
"GOLD RUSH" PRINDLE 16
overbored is offline
post #10 of 22 Old 04-08-2013
One
Always tired
Yes, depending on which ti alloy is used. However, it is easier to isolate electrically than stainless, and it doesn't suffer from crevice corrosion.
One is offline
Stainless -vs- Aluminum Cookware hriehl1 Gear & Maintenance 45 03-07-2014 03:38 PM
Stainless screws into aluminum Kiltmadoc Gear & Maintenance 23 01-01-2013 07:10 PM
aluminum or stainless rivets? caver504 SailNet FAQ 8 10-07-2010 08:14 PM
Aluminum vs. Stainless cleats bwindrope Gear & Maintenance 11 04-29-2009 06:10 PM
Turnbuckles - Stainless versus Aluminum Finallybuyingaboat Gear & Maintenance 9 10-05-2007 10:47 PM
