Keel work - SailNet Community
post #1 of 5 Old 04-08-2013 Thread Starter
slimsloslider's Avatar
Keel work
I am trying to contact JIMH about the work he did on his CAL 20. I guess I don't have enough posts to send PM.
My questions are;
What is best method to raise boat on trailer?
I know keel is heavy but with bulb resting on trailer bed how many hands required to wrangle the keel into leaning position so I can sand blast the rust?
Any body?
slimsloslider is offline
post #2 of 5 Old 04-08-2013
Skipper Jer's Avatar
Re: Keel work
Is this a swing keel? I removed the swing keel from a Venture 22. Took it to the sandblaster, blasted the rust off, epoxy coated, faired, yada, yada, yada. Reinstalling
it was a challenge until I discovered the trick.
I did this by myself.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #3 of 5 Old 04-08-2013 Thread Starter
Re: Keel work
No fixed keel quite heavy (900lbs?) hope to do work right here at the house.
post #4 of 5 Old 04-08-2013
Re: Keel work
So you want to sandblast the bottom of the bulb?
Me, I'd raise the boat by using tall saw horses and double 2x12 planks. Jack the trailer
and boat up, slid the doubled up 2x12 under the boat, 12 side against hull, support the
2x12 with tall saw horses, lower trailer. should have enough room between bulb and trailer to blast away. I didn't get that much flex when I did it working on the Venture 22.
I did nail the 2x12s together.
Nor'sea 27
post #5 of 5 Old 04-08-2013 Thread Starter
Re: Keel work
Actually its the flange area I am most focused on. I had not thought of jacking the whole rig, I will have to ponder that idea.
Seafarer 24 swing keel, keel pivot? Sailing qualities? skygazer Boat Review and Purchase Forum 44 10-21-2013 09:50 PM
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 09:43 PM
Wing Keel - how does it work? Daveinet General Discussion (sailing related) 25 11-16-2010 10:34 PM
How does a fixed keel boat differ from keel+centerboard? phboujon General Discussion (sailing related) 9 06-11-2009 10:29 PM
Rusty spots on keel and hull keel joint Stephane99 Gear & Maintenance 1 04-07-2009 07:39 PM
