Originally Posted by tommays
I have never use it BUT
1. Its the same cost as perfection give or take a buck ?
2. I have used a good bit of Awlgrip and Perfection and they apply exactly the same
You mix A AND B and then start the part science part Voodoo of how much of what thinner is going to work right when its 71.3 degrees with 47 % RH
If you get it right it they work perfect if do exactly the same thing 24 hours later and its 4 degrees cooler its going to take more of something to get the result you had 24 hours earlier
I"ve seen pictures of your boat & you are the
paint expert IMHO.
The stuff below is copied & pasted from the Petite web site.
For someone like myself, I like the more forgiving than the competition part.
•Exceptionally easy two-part polyurethane application
•Long lasting, extremely durable, high-gloss finish
•Innovative formula is practically fool-proof
•More economical and forgiving than the competition
EZ Poxy2 is a high-performance, two-part polyurethane marine
paint without all of the costs and hassles associated with two-part enamels. EZ Poxy2 combines the added gloss, wear resistance, and durability boaters are looking for in a two-part polyurethane enamel with the ease of application of a single part product. This revolutionary formula reduces the effects of brush strokes and is so forgiving; it’s practically fool-proof. In fact, EZ Poxy2 is so innovative that it makes exact mixing ratios a thing of the past. Its added UV protection and gloss retention will keep your boat looking shiny and new for years to come. It is more economical, requires less effort, and is more forgiving than the competition.
Thanks,
Bob
