outboard on my 12 foot sailing dinghy- bracket or not?? - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 04-10-2013
Re: outboard on my 12 foot sailing dinghy- bracket or not??
SchockT just reminded me of an issue I encountered. With an outboard bracket, you could leave the outboard centered, and steer with the tiller, and not have the rudder hit the prop. This is very convenient.
Without the outboard bracket, the prop would have hit the rudder, unless the outboard and rudder were always rotated together. Not convenient.
I suggest checking this, when deciding whether or not to have the bracket.
MarkSF is offline
post #12 of 19 Old 04-11-2013 Thread Starter
Had a look at the motors 'in the flesh' today.
Because the transom on the dinghy is 510 mm it looks like a long shaft would be a better fit, as typically short is for 435 mm and long is for 562.
transom thickness is a bit of challenge at 50 mm (I did say it is solid!) most of the outboard brackets look to be about 60mm. leaving no room for a packer to protect the wood.
three choices I saw today: (NZD)
Tohatsu 2 stroke 3.5 HP $1168 13 kg
Tohatsu 2 stroke 4 HP $1773 20 kg (does have F/R and a nice twist throttle!)
Yamaha 4 stroke 4 HP $1500 27 kg (2nd hand but immaculate!)
I am sensing most would steer me towards the Tohatsu 3.5?
cheers
Theo
theob is offline
post #13 of 19 Old 04-11-2013
Yes I certainly would. You're lucky you can get a 2 stroke, here it is 4 stroke only and the Tohatsu 3.5 4 stroke weighs 19kg!
MarkSF is offline
post #14 of 19 Old 04-11-2013
Outboard installation on my Wayfarer :
MarkSF is offline
post #15 of 19 Old 04-11-2013
SchockT's Avatar
Does the Tohatsu 3.5 have reverse? The older ones only had neutral, and to reverse you had to spin the motor around. Not a big deal, as long as the prop clears the transom!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #16 of 19 Old 04-11-2013 Thread Starter
no, reverse is for 4 HP up. the 3.5 has either no gear- i.e. on when you start it, or N-F
theob is offline
post #17 of 19 Old 04-11-2013 Thread Starter
yes good point, along with the thick transom, it may be useful, but the look of the thing and sending the weight aft isn't so great... decisions...decisions
theob is offline
post #18 of 19 Old 04-11-2013 Thread Starter
weird in clean green NZ isn't it?
theob is offline
post #19 of 19 Old 04-11-2013 Thread Starter
looks quite tidy- I suspect the transom to keel is a bit shorter than my Captain's Gig ? (510 mm)
theob is offline
Tags
bracket , outboard
outboard bracket for 30' champlain94 Alberg 2 11-25-2016 04:34 PM
Need help identifying outboard bracket DannyboyUpstate Gear & Maintenance 4 09-24-2012 09:19 PM
Another Outboard bracket question... LandLocked66c Gear & Maintenance 6 07-19-2011 09:17 PM
Outboard Bracket Issue YeahJohn Gear & Maintenance 7 12-02-2010 05:03 PM
Helms 25 outboard bracket Wayne25 Helms 0 10-25-2010 05:51 PM
