Go-To boat cleaner - Page 2 - SailNet Community
 7Likes
post #11 of 24 Old 04-09-2013 Thread Starter
Re: Go-To boat cleaner
Originally Posted by jrd22 View Post
I second the Imar (per Mainesails rec). Doesn't remove the wax (+) but also doesn't remove the black streaks (-). Since I wax once a year anyway I might switch to one of the recommendations above for the spring cleaning, then wax and use Imar thereafter.
I've not used it, but it appears to be a concentrate that you mix in a bucket?
If so, that's a non-starter for me. Lugging a bucket up and down the side decks, over the cabin and into the cockpit is a real PITA.
Jeanneau 54DS
Minnewaska is offline
post #12 of 24 Old 04-09-2013
Puget Sound Pounder
kellysails's Avatar
100% agree! I am completely and totally done with buckets. The EZ Jet (yes it is a Chinese POS) works. There is not an adjustment for concentration levels but likely the best $15 I have ever spent for my boat. It is EZ!!!!
kellysails is offline
post #13 of 24 Old 04-09-2013
Tim R.'s Avatar
You can also mix it in a bucket and pour into a spray bottle.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #14 of 24 Old 04-09-2013
Philzy3985's Avatar
For scuff marks it's Simple Green for quick messes or Mr Cleans Magic Eraser - That gets out anything.
1985 Catalina 30 Std Rig "A Cenoura"
itsACenoura.tumblr.com
Philzy3985 is offline
post #15 of 24 Old 04-09-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Originally Posted by kellysails View Post
OK, last hint, I can't help myself I always coil up my sheets after sailing and wrap them on the rail on the bow. I don't do this to provide the image that I am a "ship shape" type person but I find if the sheets are off the deck far less gunk collects on the deck. Sheets on the deck create little dams that trap dirt and crap.
my boat is on the hard so it's easy to collect dirt. I have a couple loose lines on my boat and the one for the main sheet, I had to tie up higher to keep from dirt lines getting on the boat. I still have a lot of scrubbing to do anyway.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #16 of 24 Old 04-09-2013
johnnyquest37's Avatar
Simple Green
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #17 of 24 Old 04-09-2013
Asleep at the wheel
jimgo's Avatar
Kelly, try partially blocking the water inlet hole (e.g., with plastic wrap, or a plastic grocery bag) to reduce the concentration of soap that gets into the water.
kellysails likes this.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #18 of 24 Old 04-09-2013 Thread Starter
Probably true, but you would have to play with the concentration. You wouldn't dilute it like in a bucket or you would have to put dozen of sprays to equal the quantity typically on a brush.
Jeanneau 54DS
post #19 of 24 Old 04-09-2013
Asleep at the wheel
jimgo's Avatar
Kelly, one more note. You might want to check out this video. Apparently the lever lets you adjust the amount of soap that gets used.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #20 of 24 Old 04-10-2013 Thread Starter
No one uses Tilex or such bathroom cleaner on their non-skid? I never have, mostly for fear of the chlorine doing bad things to the teak or paint. But, I'm tempted this year to get at those little black spec mold things we all get bits of. Maybe try to contain it and mop it back up with a wet rag, rather than hose off.
Anyway, I'm thinking that none of the products above, including my go-to, does anything for the non-skid black stuff. (someone is going to remind me what its called)
Jeanneau 54DS
Air Cleaner Assembly Afrakes Diesel 2 02-15-2012 05:36 AM
mast cleaner lgsailor19 Gear & Maintenance 3 04-30-2005 02:39 PM
varnish cleaner kimberlite Gear & Maintenance 2 03-21-2003 01:53 PM
stainless cleaner dvpamenter Gear & Maintenance 0 03-01-2001 01:37 PM
