Nincompoop ... - Page 2 - SailNet Community
 3Likes
post #11 of 17 Old 04-10-2013
No more curry buffets
Ritchard's Avatar
Re: Nincompoop ...
In case any of you have never read the extraordinary "Sliver" thread on SA, you really should, but you'll need two full days - it's now more than 5000 posts.
Here is a link to a post that begins a discussion of mating a hatch to sloping surface on the newly-build Sliver. The same process, or one you closely approximate would work for you. To make it easy for the DIY-er I might hybridize what I have suggested above, and this.
Perry Sliver Class Day Sailor - Page 51 - Cruising Anarchy - Sailing Anarchy Forums
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #12 of 17 Old 04-14-2013 Thread Starter
Learning a bit every day
FinallySailing's Avatar
Re: Nincompoop ...
Hello again. The weather has finally turned to sunny 17 degrees and I've managed to get some work done on "Rockhopper". The hatch is fully off now:
I have since managed to scrape off all the existing "Bondo". At most places it came off the original gelcoat with little resistance. At the top, where the deck was "remodelled" to have space for the hinges most of the pink filler has gone as well. You might be able to see the 2 x 1 cm hole in the right top corner of the opening ... worrysome ? This goes straight into the topside. I was going to take another picture since, but of course my mobile ran out of juice at that very moment.
I am now left with a step around most sides of the hatch opening of 4-8 mms. Most of the hatch frame was actually supported by filler ! At some places the holes for the bolts are now exposed along their side ... The hatch frame of the Lewmar hatch and the cutout in the deck certainly do not match This is going to take some effort to sort out !
Still, lots of sunshine, finally, and the best of South East English spring !!! Managed to get some other things done as well in preparation for the new season and met some nice people at the marina. Can't really complain .
BTW I've got some really good "silicone eater" that I stocked up with when a diy chain here changed suppliers. It is non toxic and smells of oranges ! So no problem getting rid of any silicone thats left. Thanks, Richard, for the link on Sailing Anarchy ... I will take all my courage together and visit their site
FinallySailing is offline
post #13 of 17 Old 04-14-2013
Tartan 27' owner
CalebD's Avatar
Re: Nincompoop ...
Well, that is progress.
I'd suggest you keep cleaning away the old putty & filler that is there. Expose all the holes and penetrations in the deck as they will need to be epoxy filled.
Sorry, I forget if you intend to re-use the hatch cover that the last owner did such a butcher job with or replace it with the original sized hatch cover that MacGregor installed at the factory? Even though MacGregor recently announced that they are ceasing production I'd bet there is a way to get a hatch cover from them.
Good luck and enjoy spring in the boat yard.
Everybody has one:
CalebD is offline
post #14 of 17 Old 04-14-2013
tommays's Avatar
Re: Nincompoop ...
I have the cure BUT it is a BIG job
It cant be goobered up worse than my hatch was as it was a complete mess and included Masonite shims
You don't even have to fix the hatch first
You will need some woodworking skill to make a template with the deck crown
Which will allow it to sit flat and seal
My hatch was BIG and a new one well over 1000 dollars so it was well worth the rebuild and i HATE leaks
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #15 of 17 Old 04-14-2013
Ritchard's Avatar
Re: Nincompoop ...
Beautiful job, TomMays.
Finallysailing, if you weren't so far away I'd come and do that job for you. No-one deserves to have inherited such crap work.
Damn.
FinallySailing likes this.
Ritchard is offline
post #16 of 17 Old 04-21-2013 Thread Starter
Re: Nincompoop ...
Ritchard, that's one of the nicest things I've heard for a long time. Thank you !!! Tommays, absolutely beautiful job you've done with your hatch.
I am off to the marina, let's see how much further I'll get today. Will post more as I progress ...
post #17 of 17 Old 04-21-2013 Thread Starter
Re: Nincompoop ...
I've now managed to chisel off as much "Bondo" as possible and removed all silicon with "silicon eater". I've made a template for the opening. There are a few places where I have to cut and sand to level the edge slightly. I didn't want to make too much dust today, out of respect of my neighbour in the boat yard who had just cleaned and polished his yacht and was also painting on antifouling. So my plan is now to fill the small holes. I will then cut a couple of panels to size and glass them into the existing opening. I'll probably have to put a couple of layers of fiberglass in between and also build up with cloth/resin in the cut out areas on the top where the hinges used to open into. Once that is all done, I'll fill and smooth the rim around it. I will not reuse the old Lewmar hatch, it is really too big for the opening. It was in part only supported by "Bondo" but would also only fit by making a recess for the hinges and building up where the original water run off in front of the original hatch was. I will get a smaller new hatch sometimes later this year, but as the sailing season is starting, I really only want to get it water tight and safe for the moment.
Tags
fiberglass repair , hatch , macgregor , silicone
