waterline leak - SailNet Community
post #1 of 7 Old 04-09-2013 Thread Starter
waterline leak
I have a very small pressure leak in my Morgan 33 fresh water system. I know its there because when things are quiet I hear the pump cycle on for a few seconds every 20 minutes or so. Am pretty sure issue dates from replacement of a 1 to 3 fixture but the clamps seem tight. Maybe pulling on the lines caused a problem elsewhere. Any bright ideas would be most welcome. Its typical sailboat, nothing is easily accessable.
like a pebble in your shoe its no big deal but annoying.
dave22q is offline
post #2 of 7 Old 04-09-2013
norahs arc's Avatar
Re: waterline leak
Do you see any water accumulating anywhere? If not it may just be seeping past the check valve in the pump and returning to the tank. (I installed a seperate check valve in the suction line because of this very reason a while back.)
Hope you are luckey enough that this is all it is.....
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
post #3 of 7 Old 04-09-2013
Re: waterline leak
Just been there... had to replace quite a few hoses to fix it. When the flexible hose gets hard, it doesn't seal well on hose barbs. I had a leak from a t that was running down the wall it was touching.
I'm afraid you just have to go around with a flashlight, and feeling with your fingers, in search of the leak.
MarkSF is offline
post #4 of 7 Old 04-09-2013
Re: waterline leak
Try putting a small piece of paper towel under every fitting and all low spots. The spot that is wet is the leak.
algee is offline
post #5 of 7 Old 04-09-2013
Re: waterline leak
If its a pressure sensitive pump, it could be the diaphragm leaking.
Jeanneau 54DS
Minnewaska is offline
post #6 of 7 Old 04-09-2013
Señor Member
PorFin's Avatar
Re: waterline leak
Another possibility:
If you have an accumulator tank, you may need to purge & re-pressurize it.
________
'85 BYB Vagabond 39
PorFin is offline
post #7 of 7 Old 04-09-2013
CapnChuck's Avatar
Re: waterline leak
I would also suggest that the pump might be a problem. If you don't see any water accumulation than the pressure switch or diaphragm might be the problem. Chuck
Our Blogs
CapnChuck is offline
Bow heavy on waterline smallboatvoyaguer Gear & Maintenance 10 11-02-2010 11:27 AM
Sealant for below the waterline... sailhog Gear & Maintenance 4 03-01-2010 05:41 PM
Painting at Waterline SuzySailor Gear & Maintenance 12 10-05-2007 10:00 PM
Waterline Ronbye Gear & Maintenance 7 05-16-2006 06:19 AM
LP below waterline? birdboat Gear & Maintenance 1 01-21-2003 02:22 PM
