Solar Power for catalina 27 - Page 3 - SailNet Community
 5Likes
post #21 of 27 Old 06-08-2013
AdamLein's Avatar
Re: Solar Power for catalina 27
Originally Posted by Alex W View Post
Clamps are visible here in the upper left:
Where'd you get these clamps?
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #22 of 27 Old 06-08-2013
tommays's Avatar
Sailrite has a nice selection of hardware
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #23 of 27 Old 06-08-2013
mitiempo's Avatar
I use Magma bbq mounts that allow you to adjust the panel's angle in seconds and lock them in place at any angle. They are more expensive than the ones pictured above but work very well.
Brian
mitiempo is offline
post #24 of 27 Old 06-09-2013
no longer reading SailNet
Alex W's Avatar
They are stocked at Fisheries Supply. They are also standard items on a lot of rail-mount hardware (Dickinson uses them for their BBQs, my Jim-Buoy life ring also uses them).
They are distributed by Sea-Dog:
Sea-Dog : Quality Marine, Industrial and Rigging Hardware
The plastic is pretty soft, so they don't have the highest clamping power. They really only work for this if used in a balanced way. They are inexpensive though.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
AdamLein (06-09-2013)
post #25 of 27 Old 06-09-2013
asdf38's Avatar
I made decent rail mounts out of PVC lumber before deciding not to use them. Cut a square or rectangle, 1" hole saw the middle, saw it in half. Bolt the two halves back together around the rail.
Though if I had known that those rail mounts were available for $10 I would have gone for those.
asdf38 is offline
post #26 of 27 Old 07-27-2013
JoeLena's Avatar
That is what I've done on my Pearson 28-2 (not yet wired when this was taken):
That is a 30 watt panel and it puts out a little over 2 amps at noon on a sunny day.
Alex, what about the support and clamps on your Pearson, where can I get that support? Looks nice and clean. And which model clamps?
Very nice!
JoeLena is offline
post #27 of 27 Old 07-28-2013
Alex W's Avatar
The clamps are from Taylor Made. Look at Maine Sail's article referenced above.
The strut is a Sea Dog Line hatch strut, it cost about $20. Like everything Sea Dog Line the quality is low and it is getting rust spots after 3 months.
Alex W is offline
Tags
batteries , charging , energy , solar panels
Who knows Solar Power? TheWollard Introduce Yourself 19 01-27-2013 01:14 AM
solar power cooljetts Electrical Systems 4 04-17-2012 03:44 AM
Solar Power for Liveaboards I33 Gear & Maintenance 7 01-14-2009 08:27 AM
yes, another solar power question....26' c&c Everlong Gear & Maintenance 2 05-28-2007 11:02 AM
Solar/Wind Power Michiel General Discussion (sailing related) 1 02-17-2006 01:45 PM
