attaching wood furring strips to inside of hull - Page 3 - SailNet Community
 8Likes
post #21 of 30 Old 04-11-2013 Thread Starter
boz86's Avatar
Re: attaching wood furring strips to inside of hull
Originally Posted by downeast450 View Post
There are no silly questions. Glad to help.
Down
Thanks much, haven't messed with these before.
"The Stone Age did not come to an end because we ran out of stone." Sheikh Yamani
boz86 is offline
post #22 of 30 Old 04-11-2013
Maybe a stupid question but I'm getting ready to work on a similar project down below what thickness should the furring strips be or is that more a matter of ionsulation needed and bending ability of the furring strip?
jbogart is offline
post #23 of 30 Old 04-11-2013
The thickness will depend on the insulation you want to add and the 'elbow room' you're willing to give up. A full inch would be as much as you'd need, I'd think, but that can encroach into the space more than you might like. I used 1/2 inch with 1/2" closed cell foam panels glued in place in between, with the battens onto that. We gained a lot of room because all that replaced a 2" thick cushion.
As for bending, the strips can be kerf-cut to facilitate that if they are not flexible enough as they are. Kerf cutting also makes keeping them in place as it cures a bit easier..
Faster is online now
post #24 of 30 Old 04-11-2013
Tundra Down
downeast450's Avatar
I steer away from resin in "paint cans". The resin from U.S. Composites comes in a gallon can with a screw cap in one corner. I am generally using small batches and like to be able to pour it out into a cup.
Down
downeast450 is offline
post #25 of 30 Old 04-11-2013
If the insulation is 1 inch the strips be 1 inch softwood. I like backcutting on table saw if a lot of curve and precut foam and use it for spacing vertical (no spiling) Horizontal ceiling can be spiled or not but beading looks good. I've found red cedar too soft and shows finger nail cuts. Yellow cedar is good but a hard wood is better It's your man cave so budget is not important. Lots of different glues work good.
Capt Len is online now
post #26 of 30 Old 04-13-2013
Over the top of the insulation do I need to place a plastic sheet or other vapor barrier like in house construction? Thanks in advance
jbogart is offline
post #27 of 30 Old 04-13-2013
I think if you use closed cell foam it will serve that purpose. Those cheap sleeping mats that backpackers use work well.
post #28 of 30 Old 04-13-2013
two part epoxy works good the 5minute kind in the siringe 3-5$ in any drug store or hardware.
mac 2-22 is offline
post #29 of 30 Old 04-14-2013
For closed cell foam, I'm using Volara. Available in rolls, and economical. I'm skinning it with stick on drawer liner which is easy to wipe down and can be replaced if damaged.
Jgbrown is offline
post #30 of 30 Old 04-14-2013
Skipper Jer's Avatar
I put up more furring strips this weekend. Have to admit the hot glue gun idea works like a champ. Saved me a bunch of time. Gorilla glue and hot glue, the bomb.
jimgo likes this.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
Glassing a old wood hull. Agri Sailboat Design and Construction 24 07-17-2012 08:33 AM
Tips for fiberglassing wood base inside hull josrulz Gear & Maintenance 15 11-07-2011 02:51 AM
lining inside of cabin with wood nodders Gear & Maintenance 7 08-25-2011 04:05 PM
Waterproofing inside a wet wooden hull brownlie88 General Discussion (sailing related) 8 06-04-2011 09:00 PM
Painting inside of Hull weephee General Discussion (sailing related) 8 08-30-2009 12:54 PM
