Bearing Buddies for trailers - SailNet Community
 1Likes
  • 1 Post By tommays
post #1 of 10 Old 04-10-2013 Thread Starter
Afternoon all,
Is there any difference in the quality of the bearing buddies from Cabela's versus those from Harbor Freight/Wal-Mart? I'd rather not order if I can pick them up locally.
jtrask is offline
post #2 of 10 Old 04-10-2013
Re: Bearing Buddies for trailers
Jtrask,
As long as they fit tight, they will work fine. It is nice to have the plastic caps also.
good luck
Dan
danr620 is offline
post #3 of 10 Old 04-10-2013
tommays's Avatar
I will post a few pictures later
Keep in mind they ONLY put a bit of grease on the outer bearing as it cant travel across the spindle to the inner bearing which is most subject to water intrusion from a leaking inner seal
The newer drilled axels that have a grease passage to the inner bearing are vastly better
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #4 of 10 Old 04-10-2013
Lake Superior Sailor's Avatar
Bearing Buddies are a poor excuse for proper maintainance and I would not waste money on them!...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #5 of 10 Old 04-11-2013
This is not true. The idea is to pack the entire spindle volume too with grease, and it will then move continuously through the outside bearing, along the spindle, and through the inner bearing.
MarkSF is offline
post #6 of 10 Old 04-11-2013
Once known as Hartley18
Classic30's Avatar
Dock
Not strictly true, Mark - it really isn't a good idea to fill the entire spindle with grease. If you do this, with nowhere else to go, the grease gets forced into places it shouldn't ever get to - like the brake shoes.
(Don't ask me how I know.. )
Not true either.. Bearing buddies allow the grease to expand and contract as the wheel/axles gets heated up and rapidly cooled down (particularly on launching the boat after a long drive!) preventing water getting sucked into the bearing and subsequent bearing failure...
I'd consider them essential myself.
Classic30 is offline
post #7 of 10 Old 04-11-2013
Classic30's Avatar
Dock
Hehe.. depends entirely on how much grease you put in, I suppose.
post #8 of 10 Old 04-11-2013
Why not pick up a set the highways are littered with them!... Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
post #9 of 10 Old 04-11-2013
Classic30's Avatar
Dock
Too true!.. another good example of what can happen if you overfill them.
post #10 of 10 Old 04-11-2013
tommays's Avatar
As a matter of fact I am and expert
stage one
stage two
Stage three
They there always leak the rear sealing area is mild steel and fails even in freshwater
They invented SS speedy sleeves to fix issues as it now has a surface a seal can stay alive on and NOT rust ASAP
They can be driven on over a sealer with some caution and primitive tools
They leave you with a PERFECT SEALING area that will NOT leak
Smart people still spend the two hours once a year to check
And travel with a road kit
The bore area were the buddy installs has a primitive size tolerance on a good day and depending on the hub they are between a hand fit and a sledgehammer
They do allow for a bit of thermal expansion BUT still only lube the outer bearing which already has plenty of grease
Tommays
Northport NY
tommays is offline
Yachting: Sailing buddies up close and personal with new cat NewsReader News Feeds 0 11-25-2012 12:00 PM
Sailing Buddies Wanted: St. Thomas gjhumphrey Crew Wanted/Available 4 04-17-2012 01:18 PM
Looking for sailing buddies.. Vince1972M34 Mass Bay Sailors 1 08-11-2009 04:29 PM
used trailers? Filmsomething Boat Review and Purchase Forum 13 08-02-2007 02:03 PM
used trailers notare Boat Review and Purchase Forum 3 07-10-2007 03:40 PM
