Trailer- cross beam weld - SailNet Community
post #1 of 6 Old 04-10-2013 Thread Starter
The trailer I have looks as though one of the cross members may be in need of a new weld. It appears that the boat was not centered when they put it on the trailer and the weight has cracked the seam of the weld.
What's a reasonable figure for having a trailer weld redone?
jtrask is offline
post #2 of 6 Old 04-10-2013
tommays's Avatar
Re: Trailer- cross beam weld
Your not really giving me much to go on BUT in general there is more involved than just goobering on some weld
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 6 Old 04-10-2013
Lake Superior Sailor's Avatar
My Dad always said;" If you have to ask you can not afford it!"....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #4 of 6 Old 04-11-2013
denverd0n's Avatar
Pictures would be helpful. Some idea of where you are at would be helpful. Details about the material would be helpful (welding aluminum is a whole different thing from welding steel).
One thing I would say is that if you can find a local 4-wheel-drive club, you will always find several of those guys who own welders, and would probably do the job for you for the cost of materials and a 6-pack.
denverd0n is offline
post #5 of 6 Old 04-11-2013
Unless the trailer was WAY overloaded good welds should last for a LONG time. Perhaps the original design allowed an unusual amount of flexing, causing the weld to fail. Or, the original weld was faulty. You might want to consider adding some extra support pieces in that area if the weight is close to the maximum carrying capacity. Suggest you find a trailer manufacturing or metal fabrication shop to do the welding, in most cases, you get what you pay for.
Paul T
dabnis is offline
post #6 of 6 Old 04-11-2013
Pull the boat and keel bracket. Grind the paint/finish off within 6" of each side of the crack. Then bring it to a welding shop. It shouldn't take more than a couple of hours to fabricate some gussets and tension plates and weld them on. If all he heeds to to is grind a little & reweld, maybe an hour. Figure $300 tops.
DonScribner is offline
JB Weld---reinforced fiberglas killarney_sailor Diesel 7 11-16-2011 09:25 AM
jb weld QuickMick Gear & Maintenance 9 06-04-2010 08:26 AM
Spinnaker Handling: 180 Turn - beam reach to beam reach? SEMIJim Racing 13 06-15-2009 09:43 AM
Glue/Weld Plastic? bhcva Gear & Maintenance 16 08-09-2008 07:52 AM
Reapiring S/S forecastle... to weld, braze or not? Lancer28 Gear & Maintenance 9 07-24-2008 09:13 AM
