teleflex model 50 uniflow valve - SailNet Community
post #1 of 5 Old 04-11-2013 Thread Starter
Yofy's Avatar
Question teleflex model 50 uniflow valve
This is a long shot but here goes. I am looking for a mechanical drawing/ breakdown of the uniflow valve from a teleflex model 50 hydraulic steering system.
I don't need a breakdown of the whole steering system JUST the VALVE. Can't find it anywhere. Maybe somebody can help?
Manny
SV Yofy
Blog: Sailing in the winds of peace
Website:
Yofy is offline
post #2 of 5 Old 04-11-2013
rugosa's Avatar
Re: teleflex model 50 uniflow valve
Patent US3908687 - MARINE STEERING CONTROL VALVE AND SYSTEM - Google Patents
Hope this helps but not sure if it is Model 50
rugosa is offline
post #3 of 5 Old 04-15-2013 Thread Starter
Yofy's Avatar
Thanks rugosa. It doesn't look like what I was searching for.
I was doing a repair on a hydraulic steering system and couldn't source exactly where the leak was coming from. I took the valve to a shop that works on hydraulics and they were stumped too. In the end I got them to change O rings and that seems to have solved my problem.
Couldn't find a breakdown of the valve anywhere though....
SV Yofy
Website:
Yofy is offline
post #4 of 5 Old 07-16-2013
Hi Yofy, I haave a drawing of the valve you want, Uniflow 50. Not sure when you posted your question, but let me know if you still require it.
Piggy.
Piggy is offline
post #5 of 5 Old 12-07-2014
I have a uniflow 50 and 2x 250v helms. i keep losing steerage and she goes out of control for a second. and then i regain steerage. I cant figure it out. I don't see any obvious leakage around the cylinder or the valve I bled the system according to the instructions on the uniflow. It seems to be functioning 90% better with the occasional slippage although it's hard to tell because there are strong currents where I am. But after being underway for about four hours I noticed my lower home which has never leaked is now leaking.
I have a large 40 in. ram that controls a 3 x 6 rider on a 20 ton steel sailboat that is 42 feet long
I am considering buying new helms and deleting the uniflow valve all together but before I spend a couple thousand dollars I would love any feedback
thanks! jonathan
Jonathan is offline
Teleflex Gauges clarity36 Electrical Systems 1 11-07-2010 10:30 AM
Need to add friction to Teleflex engine control? mbsl98 Gear & Maintenance 8 09-14-2010 04:36 PM
teleflex cables QuickMick Gear & Maintenance 0 03-02-2010 02:10 PM
Replacing SeaCock Gate Valve with Marine Ball Valve saurav16 Gear & Maintenance 30 06-15-2007 10:52 PM
Help! I am going crazy with my Teleflex Throttle Control. What is t NewsReader Mass Bay Sailors 0 07-06-2006 08:15 AM
