seized, broken bolt Boston - Page 2 - SailNet Community
 8Likes
post #11 of 14 Old 04-12-2013
Re: seized, broken bolt Boston
In the 1970's I broke off a distributor bolt and the shop welded a nut on top of it and spun it out, just the way the porsche mechanic suggests. This is routine for a good machine shop or real mechanic, as opposed to some greasemonkey.
I wouldn't try acid, that will eat aluminum and concentrated nitric is sold for cleaning stainless--it generally doesn't care about acids. Also, tends to eat the folks working with it.
Assuming you have tried Kroil or PBlaster? A real corrosion buster, not just WD40? If not, try them first. Soak, vibrate, repeat, the damned stuff is NOT WD-40 it works.
And failing that or the machine shop, i'd suggest freezing them to break the corrosion. A slush of alcohol and chipped dry ice, packed around and allowed to thoroughly freeze the parts, then removed and allowed to come back to room temp (with a heat lamp or torch to make that faster, as long as you don't ruin the temper). Or a CO2 extinguisher, or bottle of CO2 from a gas shop. Two or three good hard freeze cycles will usually break anything free, no danger of detempering metal or starting fires, just some patience and care not to get frostbite from contact.
Loctite also makes a freeze spray in a can now, but I'm not sure how effective that would be compared to really brutal freezing on the parts.
hellosailor is offline
post #12 of 14 Old 04-12-2013
Captain Obvious
Sal Paradise's Avatar
Originally Posted by benesailor View Post
i have used the same exact process as downeast describes with great success
+1
Me too, except that I used a helicoil kit afterwards ($40) and it worked perfectly and was successful. I would say to buy the very best titanium bits and work slowly from a small diameter up. Its easy.
Sal Paradise is offline
post #13 of 14 Old 04-12-2013
I have had sucess using a Dremel Toll with small carbide gutting bits. I find there is much more control than using a drill. it can be slow but effective
sailingtime is offline
post #14 of 14 Old 04-12-2013
bljones's Avatar
six SS bolts- that is going to cost a crapload of Dremel bits.
I gotta ask- how the hell does one snap SIX bolt heads? At some point you gotta say to yourself, "Okay, maybe i gotta dial down the torque, or find a better way, or something.'
It's 5 o'clock somewhere:
bljones is offline
Seized seacock sgjfrods General Discussion (sailing related) 25 07-02-2012 08:00 AM
Broken bow Chock Bolt Brucerobs2 Gear & Maintenance 2 05-10-2010 11:37 AM
Yanmar seized Islandflyr Diesel 8 10-26-2009 01:22 AM
seacock seized bluwateronly Gear & Maintenance 13 07-09-2008 08:23 PM
Seized turnbuckles zoom555 Gear & Maintenance 2 05-01-2008 11:55 AM
