Main sheet - SailNet Community
post #1 of 9 Old 04-12-2013 Thread Starter
slimsloslider's Avatar
Main sheet
Looking to rig my main sheet mid boom
slimsloslider is offline
post #2 of 9 Old 04-12-2013
Lake Superior Sailor's Avatar
Re: Main sheet
Get a Harken or Schaefer book!...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 9 Old 04-12-2013
Re: Main sheet
Here's the Harken rigging load calculator: Harken
Hudsonian is online now
post #4 of 9 Old 04-12-2013
Re: Main sheet
and is that all the information you're willing to impart?
MarkSF is offline
post #5 of 9 Old 04-12-2013 Thread Starter
Re: Main sheet
Its a Cal 20 I'm trying to finally finish and get to the water. It has a bridle at the stern, and i saw one mid boom rigged in a photo an it looked neater than having the sheet run up the cockpit. I saw pictures of ensigns rigged that way. I am new to this and don't want to screw it up. There is no class here so keeping her stock isn't necessary.
post #6 of 9 Old 04-13-2013
overbored's Avatar
Re: Main sheet
sail it the way it is designed for a while and you will find it works. it is a very small cockpit and a mid boom sheet will be in everyone way. I don't think the stock boom will take the load of mid boom sheeting.
some of the racers add a barney post in the center of the cockpit and run the sheet up the center of the cockpit under the tiller. so both the skipper and crew can reach the sheet. this takes up cockpit space when at anchor. the cam cleat in the center of the transom under the tiller works very well.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #7 of 9 Old 04-13-2013 Thread Starter
Re: Main sheet
THANKS, any advice on a deck layout for cruising? Would you advise the stock track placement or inside tracks like the racers?
post #8 of 9 Old 04-13-2013
overbored's Avatar
Re: Main sheet
the stock track for the jib is inside the shrouds. the racers put the track athwartship from just behind the aft shroud inboard across the boat to the hatch. with a good sail you can move the jib car inboard almost to the end for a very tight sheeting angle in light winds. they get rid of the winches and use a double purchase block setup. to the Cal 20 class website and there are many pics of the setup the racers use
Cal 20 Class Association > Photos
post #9 of 9 Old 04-13-2013
Closet Powerboater
MedSailor's Avatar
Re: Main sheet
Very good advice by Outbound to try it before you change it. What doesn't make sense at the dock, may suddenly make sense at 30deg of heel with one hand on the tiller....
Knuterkit posted this on my mainsheet thread and I found it a very informative resource:
Lewmar Block and winch education
Enjoy the boat!
MedSaior
MedSailor is offline
Twisted Main sheet. L124C Gear & Maintenance 38 09-15-2012 09:02 PM
Main sheet travaler nolasailor General Discussion (sailing related) 15 05-22-2011 07:30 AM
O"day 28 main sheet FourSeasMilford O'Day 2 09-11-2009 09:13 PM
How loose is your main sheet while raising the main? legarots General Discussion (sailing related) 33 06-24-2009 04:26 AM
BV and Main Sheet Block DrB Gear & Maintenance 7 08-27-2007 11:52 AM
