tuff luff - SailNet Community
Blogs
Old 06-01-2004
rbtpfe9 is on a distinguished road
tuff luff
I purchased a 30 footer in February which is equipped with what I think are two forestays. One of the forestays is equipped with a Shaefer Tuff Luff system. Given poor weather when I purchased boat I did not have opportunity to discuss much of the rigging with prior owner. In looking at sail inventory, it the genoa has hanks on it, which I would assume would be raised on the without the Tuff Luff. Is this assumption correct? As one might tell from reading this I am a novice here. Thanks for any input/advice.
Old 06-02-2004
jkumin is on a distinguished road
tuff luff
Hi:
Since no-one has chimed in......When you say equipped with two forestays assume you mean one there are two forestays permanently attached? If so are they immediately adjacent to each other or is one further aft like a cutter stay? Is the Tuff Luff part of a roller furler system or a pure racing headfoil? It is common to see a roller furler on the headstay and a bare wire inner stay several feet further aft that takes hanked on staysails, although less so on 30 footers. Your assumption is correct - jibs with hanks go on bare stays, not on Tuff Luff type extrusions. You might measure the luff length of the headstay(s) if they are different and the jib - that will provide a clue. Years ago you''d see boats with two adjacent headstays. The theory was you could hank on two jibs and wing them both out for tradewinds running.
Hope that helps.....
Old 06-03-2004
tuff luff
The stays are directly adjacent to one another. I haven''t really gone through most of the sail inventory yet and have a feeling it will become obvious which sails intended to be used on which stays. I really have not been able to find much usefull information on this particular product. Thanks for your input.
roller furling luff size thorJ30 Gear & Maintenance 0 01-14-2005 04:24 PM
Tuff Luff drynoc Gear & Maintenance 21 01-29-2004 04:31 AM
Wire or Rope Luff davejean General Discussion (sailing related) 1 11-08-2003 07:41 AM
Sail..changing from hank on to luff tape gentlerain Gear & Maintenance 1 08-21-2002 03:40 PM
Downhaul and Tuff Luffs? tjdishon Gear & Maintenance 1 03-20-2001 06:37 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
