Calculate TV 12V amps w/ 115 power supply @ 27 watts - SailNet Community
post #1 of 2 Old 04-14-2013 Thread Starter
Commodore
n8kraft's Avatar
I've got a question. On my boat I'm thinking about replacing my old non HD tv with a new HD tv. The TV in question is a Viewsonic VT2215LED 22" LED Premium HDTV Display.
On the specifications page it says the TV uses 27 Watts normally from it's 115/220 to 12V power supply. I know the formula amps = watts/volts, so amps = 27/12. If I were to hardwire the tv to my boat's 12V electrical system should I expect it to draw 2.25 DC amps?
I don't really know if that's right because the 27 Watts is listed as the draw on a 115 system, will this transfer over to 12V?
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #2 of 2 Old 04-15-2013
Aspiring to be a Mexican
sww914's Avatar
Re: Calculate TV 12V amps w/ 115 power supply @ 27 watts
Yes, you're about right and it may be even less due to the inefficiency of converting from 110 to 12v through their power supply.
IM trusting your math, i don't have a calculator on the ipad ind it's too late for long division.
sww914 is offline
Iridium power supply riddon Electronics 0 01-16-2012 10:10 AM
A/C Power Supply Help Leocat66 Gear & Maintenance 7 11-15-2011 08:58 AM
Use a DC Power Supply? Tree Electrical Systems 17 08-20-2010 01:03 PM
800 watts = $160! deniseO30 Electrical Systems 27 04-22-2010 09:40 AM
How do you calculate spinnaker size needed Stillraining Gear & Maintenance 9 10-12-2008 11:34 PM
