I'm a tiller guy, not really a wheel guy... - SailNet Community
 1Likes
post #1 of 11 Old 04-15-2013 Thread Starter
...as with a tiller, I always felt I had more control of the boat. As my boats got bigger, the tiller changed to a wheel. The wheel on my present boat rotates five 360 rotations lock to lock with hydraulic steering. It's a 62' modern trimaran, sails fast, but it is difficult to dock because the wheel spends like a top maneuvering the boat, as you might imagine. I would prefer a single 360 degree turn lock to lock. I feel as though I would have more control. Legitimate request? Smart request? Any help would be appreciated...
p1pel1ne is offline
post #2 of 11 Old 04-15-2013
I don't discuss my member
zz4gta's Avatar
Re: I'm a tiller guy, not really a wheel guy...
I would think that with hydraulic steering you're ratio would be a lot less. Check out the mechanism and change it to something with a lower ratio.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #3 of 11 Old 04-15-2013
Six turns is almost back to the days of Square riggers and spoked wheels.. very odd that you've got that ratio.
So... legitimate request IMO. Is it a production Tri or a homebuilt?
Faster is offline
post #4 of 11 Old 04-15-2013
SchockT's Avatar
I have never seen hydraulic steering on a sailboat, but my understanding is it is much like the hydraulic steering systems I dealt with way back in my Heavy Duty Mechanic days.
If I am correct, then you essentially have a hydraulic pump attached to the steering wheel which transfers hydraulic oil from one side of a hydraulic ram to the other. If the seals are failing in the pump or there is air in the system it may not be moving as much oil, and therefore it may take more turns lock to lock. 5 turns sounds rather excessive!
Another thought; could it be related to linkage between the hydraulic cylinder and the rudder? Presumably the ram connects to a tiller bar. Can the ram be connected to the tiller closer to the rudder, thus requiring less travel lock to lock?
Of course I could be wrong, and 5 turns could be normal! I'm just throwing ideas out there!
I can't imagine there is much helm feel with hydraulic steering.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #5 of 11 Old 04-15-2013 Thread Starter
Custom Tri, carbon fiber, powerful and fast. I'm thinking two 360's lock to lock would be the best.
p1pel1ne is offline
post #6 of 11 Old 04-15-2013
SchockT's Avatar
If the existing system is functioning correctly, then it is likely a factor of pump sizing. A larger capacity pump on the helm will transfer oil faster, and give you faster steering.
Hull#101
SchockT is offline
post #7 of 11 Old 04-16-2013
Wonder if the steering feels spongy at all? Does it need bleeding? A lower volume ram might help too...
Faster is offline
post #8 of 11 Old 04-16-2013
Asleep at the wheel
jimgo's Avatar
By making such a change, are you worried that you're going to sacrifice some of the sensitivity in the steering? I would think it's kind of like going from my 7,000 lb SUV to a Miata - the gas and brakes will be MUCH more responsive than what I'm used to. I would be concerned that the tighter steering would make it harder to make subtle corrections in your heading. But maybe it's just a function of getting used to the new set-up.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #9 of 11 Old 04-16-2013
Six full turns is really excessive and would be exhausting in a seaway. Can't see any reason why that would be desirable or necessary.
Ajax_MD likes this.
Faster is offline
post #10 of 11 Old 04-16-2013
Old enough to know better
That is what I was thinking that it would make it too jittery. It does seem to be a bit much. I would be worried that it would make the effort too great when out at sea, especially when the wind pipes up. Of course on my Miata I removed the power steering pump to give me more road feel. But some think it is too much in a parking lot, but most of the time I am in parking lots I am going around cones! I would think reducing the ratio might make it too hard to steer.
Is there any linkage between the wheel and the pump that you might be able to change the gear ratio? that would be an easily reversible change.
miatapaul is offline
Tiller vs. Wheel Paisan General Discussion (sailing related) 35 11-03-2010 06:42 AM
Tiller vs wheel flyingwelshman General Discussion (sailing related) 26 09-15-2009 01:13 PM
Tiller or wheel? AllThumbs Boat Review and Purchase Forum 41 09-03-2009 01:56 PM
Tiller or Wheel? Hooah Seamanship & Navigation 8 04-01-2006 01:34 AM
Wheel to Tiller TADIAS General Discussion (sailing related) 3 06-16-2005 04:20 PM
