What size rivet? - SailNet Community
post #1 of 12 Old 04-15-2013 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
What size rivet?
I am looking to attach my winch handle holder to the mast using rivets. What size rivet should I purchase? I am not exactly mechanically inclined.......
brokesailor is offline
post #2 of 12 Old 04-15-2013
Re: What size rivet?
Hard to answer, broke. You need to get a rivet that has a compression depth matching the combined thickness of the holder and mast. Can't know what that is from afar.
Be careful when drilling into your mast, as you don't want to hit anything inside. Assuming you have an aluminum mast, I would use aluminum rivets too.
As an aside, I'm not a huge fan of having things on the mast that could snag a line.
Jeanneau 54DS
Minnewaska is offline
post #3 of 12 Old 04-15-2013 Thread Starter
SV Skalliwag #141
Thanks Minne. Sounds like you are saying that rivet size refers to the length of the "head" of the rivet. I thought it referred to it's girth?
My lines get snagged on just about everything on the foredeck but I can't imagine them getting snagged on the winch handle holder! To many other things to get snagged on!
post #4 of 12 Old 04-15-2013
Found this for you. There is both diameter and compression range to consider. First, you'll need to know the thickness of the holder and mast.
Fastener Mart: Understanding Blind Rivets
I was thinking of lines being caught on the winch handle too.
Jeanneau 54DS
post #5 of 12 Old 04-15-2013
Old as Dirt!
svHyLyte's Avatar
There is no need of a mechanical fastener in a winch handle holder at all. Its not loaded. Use an adhesive sealant material applied to the back of the holder. One could use 4200 (NOT 5200!) for example. Position the holder where you want it and fix in place overnight with some masking tape while the sealant cures. No holes needed. I have done this with both cockpit holders and mast holders for years and have never had one break free.
FWIW...
svHyLyte is offline
post #6 of 12 Old 04-15-2013 Thread Starter
SV Skalliwag #141
What size rivet?
Never thought of it! I guess I can try that first. I have it presently attached with tie wraps. Not very nautical looking.
post #7 of 12 Old 04-15-2013
blutoyz's Avatar
I would keep a spare below just in case the sealant lets go...
blutoyz is offline
post #8 of 12 Old 04-15-2013
Old as Dirt!
svHyLyte's Avatar
One that I attached to the mast of our prior yacht, a 1976 Cal 2-29, in 1987 is still attached although the pocket itself has needed occasional coatings with NicroCote over the years. Likewise the three that I have attached to our current yacht, two in the cockpit and one on the mast, since 2001.
FWIW...
svHyLyte is offline
post #9 of 12 Old 04-15-2013
Wish I never found SN!
SimonV's Avatar
Mine is held on using hose clamps.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #10 of 12 Old 04-15-2013
overbored's Avatar
don't know your boat but make sure you place it so the jib sheet will not hang on the handle or you will have installed a Winch Handle Launcher. if you angle it slightly forward it will increase the launch distance so the handle will clear the foredeck and avoid any dings in the deck. I believe the current cost per launch is about $75. Remember to remind anyone on the foredeck to keep on eye on the handle during a tack so they will have time to duck, you want them to be able to help clean the boat at the end of the sail.
"GOLD RUSH" PRINDLE 16
overbored is offline
Setting a rivet into a tight spot Irunbird Gear & Maintenance 4 10-02-2012 06:32 PM
Glue, screw or rivet spinnaker pole ends? rhr1956 Gear & Maintenance 8 05-19-2012 06:22 PM
Does size matter?? Wheel size, that is... Undadar Gear & Maintenance 9 09-17-2011 07:39 PM
Is there a go-to manual rivet gun for stainless rivets? oomfh Gear & Maintenance 2 04-25-2011 07:07 PM
Slip size and boat size. rikbass Announcements and Suggestions Box 12 09-14-2010 02:52 PM
