outboard fuel tank - SailNet Community
 1Likes
  • 1 Post By tommays
post #1 of 9 Old 04-15-2013 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
outboard fuel tank
Are the fuel tanks with the vent on the fill cap now ilegal? (EPA Ruling)
brokesailor is offline
post #2 of 9 Old 04-15-2013
Mermaid Hunter
SVAuspicious's Avatar
Re: outboard fuel tank
How can you possibly get the fuel out of a tank without a vent of some sort?
SVAuspicious is offline
post #3 of 9 Old 04-15-2013
tommays's Avatar
They are trying like hell for diurnal fuel tank emissions vents on installed tanks but the reality that a boat fuel system has different safety issues is slowing it down
On portable tanks so far they have just done self closing spouts that ensure you spill the most possible fuel while using them
T37Chef likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #4 of 9 Old 04-15-2013 Thread Starter
SV Skalliwag #141
outboard fuel tank
The new tanks at WM will allow the tank to pressurize up to 5 psig I think without letting it vent. It will keep the tank from drawing a vacuum. This info is off a WM video.
post #5 of 9 Old 04-15-2013
pdqaltair's Avatar
Yes, this from the Federal Register:
eCFR — Code of Federal Regulations
(c) Portable marine fuel tanks and associated fuel-system components must meet the following requirements:
(1) They must be self-sealing when detached from the engines. The tanks may not vent to the atmosphere when attached to an engine. An integrated or external manually activated device may be included in the fuel tank design to temporarily relieve pressure before refueling or connecting the fuel tank to the engine. However, the default setting for such a vent must be consistent with the requirement in paragraph (c)(2) of this section.
(2) They must remain sealed up to a positive pressure of 24.5 kPa (3.5 psig); however, they may contain air inlets that open when there is a vacuum pressure inside the tank. Such fuel tanks may not contain air outlets that vent to the atmosphere at pressures below 34.5 kPa (5.0 psig).
I'm not sure any percieved benifit off sets potencial safety issues for these small tanks, but it is true.
Installed tanks can vent though carbon canisters. Based on quite a bit of personal testing, I think this actually benifits the boater, if the design is good. The canisters reduce fuel loss by several gallons per year (both $$ and preserving the most volitile fraction), improve fuel oxidation stability (less oxygen), reduce water absorption (important for e10), and reduce fuel system (carb) corrosion; I've been able to reproduce these benifits in the lab and on the water.
Sail Delmarva: Gasoline and Fuel Tank Vent Filters
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #6 of 9 Old 04-15-2013 Thread Starter
SV Skalliwag #141
outboard fuel tank
PDQ are you a mad scientist? 😎
post #7 of 9 Old 04-15-2013 Thread Starter
SV Skalliwag #141
outboard fuel tank
So what's the penalty if you get caught out there with the external vented tank?
post #8 of 9 Old 04-15-2013
tommays's Avatar
Its a going forward standard that does not affect old installs
I have sure not seen a portable 3 or 6 gallon tank that does well with 5 PSI ?
Even my best CARB compliant plastic tank has fits within the confines of my fuel tank friendly garage and it would seem the old school metal tanks would be far more up to the task of containing the pressure fluxuations
I find the fact that they phased out the "outdated" station recovery systems rather absurd as it is when by far when I smell the most fumes but we spent a large fortune on that failed experiment
Tommays
Northport NY
tommays is offline
post #9 of 9 Old 04-15-2013
I've been using one of the new 3 gal tanks for 9 months now - it seems to work just fine.
MarkSF is offline
Outboard Fuel Economy/Sizing tschmidty General Discussion (sailing related) 16 01-04-2013 09:25 PM
outboard fuel tank problem MarkEric Gear & Maintenance 3 11-03-2011 02:21 PM
Outboard engine w/integrated fuel tank? AboardIndigo Gear & Maintenance 8 12-25-2007 09:32 AM
Outboard fuel storage leelocke Gear & Maintenance 2 04-12-2005 01:30 PM
outboard fuel pump strength wgwl13736 Gear & Maintenance 5 08-16-2004 08:03 AM
