FJ in need of blocks, newbie at helm. Help! - Page 3 - SailNet Community
post #21 of 26 Old 05-06-2013
Barquito
Barquito's Avatar
Re: FJ in need of blocks, newbie at helm. Help!
Have you gotten out on the water on your FJ yet?
Nope. Looking forward to some warmer weather, so I can get the thing out. The bow compartment normally has a wood cover. Not sure of the maker. I think it is Canadian. Still trying to get the maple syrup out of the bilge.
Again, I would keep the rigging simple until you figure out what you really need. Just run a rope, between two tangs on the transom for your traveler. My mainsheet consists of a block on the aft end of the boom (pictured), and one about mid-boom. The sheet goes down to the block at the front of the cockpit (could also be further back, I think). In the pictures, notice that there is a block next to the cleat. The jib sheet would go thru the block to the cleat on the other side of the boat. Don't spend too much time fixing, at the expense of sailing.
Valiant 32
Barquito is offline
post #22 of 26 Old 05-06-2013
Tartan 27' owner
CalebD's Avatar
I'll also weigh in on keeping your rigging simple to start with.
You should be able to sail it just fine with decent jib & main sheets. Add a traveler and you should be able to sail upwind a little better. Add a boom vang and you should be able to sail down wind a little better. I think that it is a good idea to know how to sail your boat well with the simplest of controls as you will then appreciate the ways that a traveler & vang can help shape the sail.
One of the reasons I like sailing a Sunfish is there is almost none, zero rigging on it; just a halyard and a sheet.
Everybody has one:
CalebD is online now
post #23 of 26 Old 05-06-2013
Beginers need oto be cautious about not being conned ninto buying a lot of useless stuff they dont need, and may better of without. Keep it simple. go sailing simply , then slowy decide, based on your ever increasing experince, what you really need.
Brent Swain is offline
post #24 of 26 Old 05-06-2013
Originally Posted by FlyingJunior View Post
I get it, now I'm inspired to make my own ropes, sails, spars, rigging, compass, gps, head and hull. No more consumerism for me.
The suggestion being that, if you can't make your own GPS, then you should never attempt to make your own blocks, or anything else for that matter?
I will have to stop saying "How stupid can you be." Some seem to be taking it as a challenge.
post #25 of 26 Old 05-06-2013
Or how much time one can waste making a $3 block for a dink. I really think you're joking about this.
FlyingJunior is offline
post #26 of 26 Old 05-07-2013
I don't discuss my member
zz4gta's Avatar
BS is not joking. Search his other posts.
zz4gta is offline
Weather helm on starboard, lee helm on port donlofland Gear & Maintenance 3 01-17-2012 05:49 PM
Newbie sailor, newbie to sailnet aarhus Introduce Yourself 2 06-16-2010 03:59 AM
Weather Helm vs Lee Helm grantheadifen Learning to Sail 4 06-22-2009 05:23 PM
Best Blocks for the Money?... DrKirk Gear & Maintenance 5 03-08-2004 07:30 PM
Mariner Blocks G.Robles Gear & Maintenance 0 10-23-2000 12:28 PM
