Hull-deck joint - suggestions needed Int'l Folkboat - SailNet Community
post #1 of 7 Old 04-15-2013 Thread Starter
hello -
the previous owner of this Int'l Folkboat solved some hull-deck joint leaks with caulk. i need to figure out whether to take off the old caulk and redo the same sort of thing, or epoxy it, or something else.
since this will be only my 2nd year as a member of the yachting class i'd prefer simple and good to complicated and excellent. your guidance would be much appreciated and carefully considered.
Hull-deck joint - suggestions needed Int'l Folkboat-hull-deck-joint-if-biggest-hole.jpg
Hull-deck joint - suggestions needed Int'l Folkboat-hull-deck-if-joint-2.jpg
juggleandhope is offline
post #2 of 7 Old 04-15-2013
tommays's Avatar
Re: Hull-deck joint - suggestions needed Int'l Folkboat
The curse of the molded fiberglass toe rail
My Cal 29 suffered from the same issue
The caulking rework is the only reasonable thing to do outside
That is dig it out and caulk it again as with some careful taping you can do a neat looking job
If there is and issue with the joint failing in some manner , why else would it leak
And inside repair while messy does not shine a spotlight your work
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 7 Old 04-16-2013
Hello, IF boats are the best. I have an 1975 Marieholm IF. I've got a small leak port side amidships.
Slight gap in the caulking. Is it best just to repair the small area or completely redo the entire caulking? Thanks.
sfseasailor is offline
post #4 of 7 Old 04-16-2013
Tartan 27' owner
CalebD's Avatar
Looks like too big a gap for Butyl tape.
Why wouldn't filling that gap with epoxy/thickeners & cloth be a good idea?
Everybody has one:
CalebD is offline
post #5 of 7 Old 04-17-2013
Large Member
I'm not familiar with an International Folkboat but how is the deck attached to the hull? I would be more worried why there is a gap there. For example if the deck is attached with bolts and they have become loose, caulking wouldn't be the first thing on my list. Do other IF's have a gap & caulking there?
If there is no structural issues, then clean all the old caulk off and use a good quality marine sealant.
Marine Caulking and Adhesive Sealants 3M Sikaflex Boatlife
mdbee is offline
post #6 of 7 Old 04-27-2013 Thread Starter
agree - that's the plan. and bought some 3M 4000 for caulking the whole hull-deck joint.
thanks for the suggestions.
post #7 of 7 Old 04-27-2013
Senior Moment Member
SloopJonB's Avatar
That looks like an appropriate place to use 5200 - the more adhesive & permanent the better I would think.
SloopJonB is offline
Tags
deck , folkboat , hull , international folkboat , joint
help me with my hull to deck joint!! jaymckay Gear & Maintenance 6 11-13-2012 08:51 AM
Seeking opinions for deck and hull-deck joint repair gregor1234 Gear & Maintenance 8 04-26-2012 12:10 AM
Deck to Hull Joint voice3 Sailboat Design and Construction 9 11-03-2008 06:10 PM
hull deck joint ArgleBargle Sailboat Design and Construction 5 09-28-2008 08:45 PM
Split deck cap and leaking hull/deck joint alaskaboy Gear & Maintenance 2 01-04-2008 10:25 PM
