Material for use as stiffener in sunbrella winch handle holder (diy) - SailNet Community
 2Likes
post #1 of 12 Old 04-17-2013 Thread Starter
After my very successful new mainsail cover project, I want to make a cockpit sheet bag that has a winch handle holder incorporated into it, maybe a beer holder too.
To make the winch handle holder, I need something stiff to sew into the lip so it stays open instead of flopping down. I considered a 1/16"x3/4" strip of aluminum or stainless, but I am concerned that if I step on it accidentally it won'r retain its shape. Plus I feel like usually some sort of plastic is used in these applications...
Any ideas on what to use? (and where to get it)
PS it would look something like this:
peterchech is offline
post #2 of 12 Old 04-17-2013
Re: Material for use as stiffener in sunbrella winch handle holder (diy)
You might join the Sailrite forum and post the question. Questions are usually answered quite quickly.
Sailrite Forum
TejasSailer is offline
post #3 of 12 Old 04-17-2013
overbored's Avatar
you could use a scrap of laminate sail material. I have done this on a cover where the windows are to keep the fabric stiff so it would not flap against the window plastic. a couple of layers sewn together makes it very still like cardboard but it will give if you lean on it
"GOLD RUSH" PRINDLE 16
overbored is offline
post #4 of 12 Old 04-17-2013
no longer reading SailNet
Alex W's Avatar
I've used heavy duty zip ties slipped into the sleeve for the same purpose (but in a different application). They are thin and have the right mix of stiffness and flexibility.
Alex W is offline
post #5 of 12 Old 04-17-2013
FSMike's Avatar
What about using a plastic bottle with the top cut off? Get one thick enough to hold its shape. If it dies it would certainly be cheap to replace.
jimgo likes this.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #6 of 12 Old 04-17-2013
Any plastics store should stock plastic sheets, or teflon gasket sheet material would do too. Even craft stores may have something appropriate. UV isn't going to be an issue because it's encapsulated in sunbrella.. but cutting up an old bleach bottle/yogurt tub may be your least expensive route.
jimgo likes this.
Faster is offline
post #7 of 12 Old 04-17-2013
Tim R.'s Avatar
That's easy. Use some 40 gauge vinyl window material. Will stiffen your bag(no puns please) and you can sew through it with the proper machine and needle. You should be able to get a strip that small as a scrap from a local canvas shop.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #8 of 12 Old 04-17-2013
trantor12020's Avatar
Good recycle idea.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #9 of 12 Old 04-18-2013 Thread Starter
Bleach bottle sounds like the right type of plastic how did I not think of that lol
The vinyl and Old laminate sails are a good idea too because you can sew through them, but I don't know if my cheap sewing machine will handle it, I think an insert of some sort is best...
post #10 of 12 Old 04-18-2013
Asleep at the wheel
jimgo's Avatar
Don't sew through the bleach bottle, sew around it. If you want to be really anal, glue the fabric to the surface, but sew around the outside.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Looking for an old winch handle j1brady Gear & Maintenance 22 10-01-2010 08:37 PM
winch handle marthajewel Gear & Maintenance 7 02-25-2009 10:57 AM
Winch Handle Holder Siamese Gear & Maintenance 24 11-06-2008 02:30 PM
Winch Handle Holder On the Cheap Siamese Gear & Maintenance 18 05-23-2007 01:39 AM
Winch Handle Holder THOMASRHEUBLE Gear & Maintenance 11 10-21-2006 07:37 AM
