03-21-2001
Leakey windows
the only way to stop the leaking is to remove the windows, clean them thoroughly and rebed them using silicone caulk. Unless you remove them they will continue to leak no matter how much "goo" you apply. If you are afraid of destroying the windows, just replace the lexan with new. If you are going to remove them,I''d replace them anyway. the material is very cheap.
