Garelick Motor Mounts - Your Experiences - Page 2 - SailNet Community
post #11 of 17 Old 04-18-2013
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: Garelick Motor Mounts - Your Experiences
The Garhauer is not cheap; mine was $392 delivered.
Defender lists the super-duper Garelick (303618) at $380.
I'm making my inside backing plate from 1/2" marine ply; I think the same thickness of StarBoard would be enough.
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is online now
post #12 of 17 Old 04-18-2013
CS Cruiser's Avatar
Dock
This is for two stroke only, I used the 4 stroke version since my motor is heavier, but you mentioned yours is 100lbs.
STAINLESS STEEL AUXILIARY OUTBOARD MOTOR BRACKETS FOR 2-STROKE MOTORS
MODEL NUMBER: 71056
Easier to lift and lower Stainless springs help counterbalance motor weight.
Transom mount locks and holds motor up or swings down for propulsion.
Built in transom angle adjustment allows optimum motor performance.
Fits all style motors Extra Wide (11 1/2" 29cm) Black Poly Mounting Board for newer, wider style motor locking clamps.
4 position locking height adjustment.
Stainless Mounting Hardware & instructions included.
Wide track body for added stability.
Made of tough 304 Stainless Steel.
MOUNTING PAD 2" thick x 11 1/2" wide (5 x 29cm). Designed to also accommodate the width dimensions of late model auxiliary outboard motors.
SPECIFICATIONS:
H.P. Rating: Over 7 1/2 to 20.
Motor Weight Not to Exceed: 115 lbs.
Vertical Travel*: 11 1/4" (29cm).
Mtg. Pad: Poly.
Mounting Board Dimensions W x H x T: 11 1/2" x 10 3/4" x 2" (29 x 27 x 5cm).
Mounting Bracket Dimension W x H: 7 5/8" x 7 7/8" (19 x 20cm).
*Vertical travel is based on transom angle being perpendicular to the water.
http://www.thechandleryonline.com/im...pup/153_AGAR71
GARELICK/EEZ-IN #71056, STAINLESS 2-STROKE OUTBOARD MOTOR BRACKET.
The Chandlery Online #: 153_AGAR71056
Be the first to review this product
Our Price: CAD$209.85
USD$209.85
Paul
s/v TENACITY - CS36T
CS Cruiser is offline
post #13 of 17 Old 04-18-2013
Load Bearing Member
Dock
Originally Posted by SailingJackson View Post
My Catalina 25 had the Garhauer mount and an overweight Honda motor. The Garhauer frame and welding was great but, after a few years of pounding on Lake Michigan, the bearings and shafts all went out. I rebuilt by turning some beefy Delrin bearings and it worked fine for years. The springs are not enough lift. I added some tiny Harken blocks with 4 pulleys for an 8:1 purchase. That made the lift very easy.
Thanks, Jackson. The CatDir site said they had re-engineered the mounts with bronze bushings. Not sure if they mean all of them or just the heavy-duty one.
I am considering some sort of retaining strap to hold it in the raised position. Even though the mount is beefy, it is still a lot of weight attached to a 12"x12" area of my transom. I'd like some kind of connection to prevent it from bouncing.
FYI - the vertical rails (that mount to the transom) are 3" longer on the heavy-duty model. They stick down lower to distribute the weight better. I'm not installing an outside backing plate, just an inside one.
Ken
Zen Again
post #14 of 17 Old 04-18-2013 Thread Starter
Sundance 23
carl762's Avatar
Bingo, Paul, you hit her right on the head. Couldn't get the page to load, but I read your description. This was exactly what I was thinking about.
Garelick 71056 Auxiliary Outboard Motor Bracket-71056 Garelick
Although all the others mentioned here look great, I think this baby will do the trick for $164 and change, plus s/h.
1/2" backer, got it. Got too busy last evening to get inside and take a look. Heading down again tonite after work.
Garelick it is.
Thanks again, everybody, for your responses.
Water is Life
carl762 is offline
post #15 of 17 Old 04-18-2013
I have the motor mount (4 spring version) from CD on my C25 with a 9.9 Merc Bigfoot at 108 lbs. It works great. I did put a spacer board on it for the motor clamps and bolts just to use up some of the space. The 9.9 4 stroke was a bit deeper on the transom brackets than my previous 7.5 2 stroke.
WesAllen is offline
post #16 of 17 Old 04-18-2013
CS Cruiser's Avatar
Dock
Garelick it is.
Excellent price Carl, you can't go wrong with that. I had to pay double for the 4 stroke version. Hope it all works out for you.
Paul
post #17 of 17 Old 04-19-2013 Thread Starter
Sundance 23
carl762's Avatar
Thanks. Got some expert help, so we can get it all together right.
It'll be so nice to sail this year the right way: with the motor out of the water.
Thanks guys.
Water is Life
carl762 is offline
broken motor mounts bristol299bob Diesel 4 03-26-2013 09:54 AM
C&C 33 motor mounts barryschnur C & C 1 08-31-2011 07:48 PM
R&D (PYI) Motor Mounts for Yanmar jason3317 Gear & Maintenance 9 03-15-2010 07:46 PM
Motor Mounts on Yanmar DrB Gear & Maintenance 12 01-14-2010 07:26 PM
Stanchion motor mounts bsfree Gear & Maintenance 0 06-07-2002 10:27 AM
