Garelick Motor Mounts - Your Experiences - SailNet Community
post #1 of 17 Old 04-17-2013 Thread Starter
Sundance 23
carl762's Avatar
Well, the old motor mount for the 9.9 Evinrude is just a bear. It takes all my strength to pull motor up out of the water. It's time to replace. Bottom line is the motor's lower stayed in the water on the Columbia all winter because of this difficulty. My very knowledgeable friend just went through the motor, laboring several hours cleaning up the corrosion. She runs great, but is not going back on the boat until I get a new mount installed. I don't want to have to spend any more money this year on the motor.
I searched the forum and see some folks have used this brand. My research has led me to the 118 pound model.
What do you'all think? Anything a better bang for the buck? I don't mind spending the cash on the best I can get.
Water is Life
carl762 is offline
post #2 of 17 Old 04-17-2013
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: Garelick Motor Mounts - Your Experiences
Catalina Direct sells one made by Garhauer (sp?); it is as beefy as all get out and has 4 SS springs. Rated for 95-115#. The swing arms are rectangular boxes of welded SS tubing. I just bought one to hold my 117# Honda. I haven't installed it yet.
I bought this one because I already had the same model with fewer springs (you can't add them; they're welded into the box arms) the old one was strong enough, just needed more springs; this one is stronger.
The cost is about the same as the Garelick. I'm not dinging the Garelick (I think my previous boat had one), I'm just saying the Garhauer is well made.
Ken
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #3 of 17 Old 04-17-2013 Thread Starter
Sundance 23
carl762's Avatar
Thanks. I took a look at the site, and I just don't see motor mounts anywhere. I'll keep looking.
Water is Life
carl762 is offline
post #4 of 17 Old 04-17-2013
CS Cruiser's Avatar
Dock
I just installed a Garelick for my 9.9 last season, works like a dream with very little effort, highly recommend. Model 71090 used with XL shaft.
Paul
s/v TENACITY - CS36T
CS Cruiser is offline
post #5 of 17 Old 04-17-2013 Thread Starter
Sundance 23
carl762's Avatar
Thanks much. Just what I wanted to hear. Tired of busting my A$$ on that motor.
Water is Life
carl762 is offline
post #6 of 17 Old 04-17-2013
Ken
My Catalina 25 had the Garhauer mount and an overweight Honda motor. The Garhauer frame and welding was great but, after a few years of pounding on Lake Michigan, the bearings and shafts all went out. I rebuilt by turning some beefy Delrin bearings and it worked fine for years. The springs are not enough lift. I added some tiny Harken blocks with 4 pulleys for an 8:1 purchase. That made the lift very easy.
GJ
SailingJackson is offline
post #7 of 17 Old 04-17-2013
CS Cruiser's Avatar
Dock
They offer a few models on their website, just filter for two stroke or four stroke and the models will appear accordingly, be sure the travel of the model chosen will suit your mounting height and motor shaft length etc.... The travel for lift dimensions can be miss leading, but as long as you understand the difference between lift and final resting position(s) you can work it out , mechanically very well put together and again very easy to operate!
Paul
post #8 of 17 Old 04-17-2013 Thread Starter
Sundance 23
carl762's Avatar
Cool. The existing motor mount is bolted to a box-like structure on the transom. It makes it even more difficult to reach the motor. I don't think it's removable.
I'm going to crawl into the bilge area and work my way back to the transom to see what it looks like on the inside. I'm pretty sure I'll see rotten plywood backing as I've found in other areas of the boat. I'd like to get the old mount off tonight, so I can take measurements for its replacement. Planning on using starboard for a backing plate. How thick should it be?
Thanks again for all your replies.
Water is Life
carl762 is offline
post #9 of 17 Old 04-17-2013
tommays's Avatar
I do NOT care for the switch from the marine plywood to plastic as you its the one area that is iffy with the weight of newer four-strokes
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #10 of 17 Old 04-17-2013 Thread Starter
Sundance 23
carl762's Avatar
This is a 100 lb (I'm told) 2 stroke Evinrude.
Ah, found the motor mounts at Catalina Direct. Very expensive, with extra fee for packing and over-large item shipping. I really like the one with stainless tubing.
Water is Life
carl762 is offline
broken motor mounts bristol299bob Diesel 4 03-26-2013 08:54 AM
C&C 33 motor mounts barryschnur C & C 1 08-31-2011 06:48 PM
R&D (PYI) Motor Mounts for Yanmar jason3317 Gear & Maintenance 9 03-15-2010 06:46 PM
Motor Mounts on Yanmar DrB Gear & Maintenance 12 01-14-2010 06:26 PM
Stanchion motor mounts bsfree Gear & Maintenance 0 06-07-2002 09:27 AM
