Removing Bottom Paint - Page 2 - SailNet Community
 11Likes
post #11 of 68 Old 04-19-2013
tommays's Avatar
Re: Removing Bottom Paint
I use a carbide drag scraper I found at Home depot with 4 dollar replacement blades
I am and old but motived person and once you get the feel it is a bit painful but progresses rather fast
tarps a good shop vac keep things in control
Sabreman likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #12 of 68 Old 04-19-2013
fallard's Avatar
Tommay's drag scraper is the kind I used and recommend. The key (for my situation) was to apply pressure against the hull as you drag the scraper along. That's how you fracture the paint, allowing the scraper to peel it off rather easily.
fallard is online now
post #13 of 68 Old 04-19-2013
Good idea to check with the yard. Its bizzare what rules exist on how one must do things. Around here, yards cut deals with the Dept of Environmental Mangement all the time. The DEM won't make them install things like reclamation for pressure washer water, if they agree to modify some other practice. They may, just for example, agree to only use vacuum collectors on sanders so that scrapings and blasting residue never touch the ground. I'm not saying I know of this specific example, but I know of some that are just as silly.
Jeanneau 54DS
Minnewaska is offline
post #14 of 68 Old 04-19-2013
Sorry to hijack the thread, but how far down do you sand if the previous coat isn't in bad shape? All the way to the gelcoat?
FirstCandC is offline
post #15 of 68 Old 04-19-2013
Depends. If the new paint is compatible with the old, you only need to take it down to that which is still adhered well. Safe is to take it to whatever epoxy barrier coat may have been applied, unless that is letting go to.
Jeanneau 54DS
post #16 of 68 Old 04-19-2013
Thanks. Going with Micron Extra over Micron Extra. Sanding upside down is NOT fun!
post #17 of 68 Old 04-19-2013
....Sanding upside down is NOT fun!
That's for sure. It's also one of those jobs where you can get very cheap unskilled labor to do it for you, while you focus on chores that a yard would charge $90 per hour to do. Many yards, however, won't let you bring your own help. Some will, if you are there with them or pay the yard a vig.
Jeanneau 54DS
post #18 of 68 Old 04-19-2013
Sabreman's Avatar
I got my unemployed brother-in-law to help. Quite cost effective and he was happy for the work. Tommay's scraper is the one that I used too.
Using a ShopVac isn't just efficient, it's smart health-wise and environmentally. The tarp that we had beneath the boat contained about 50 pounds of paint chips that we hauled to the dumpster. When sanding, I pulled off another 5 or 10 pounds, some of which would have ended up in my lungs (I sand each year so it's recurring). The thought of letting it just fly into the air for others to breathe or eat seems wrong to me.
Sabre 38 "Victoria"
Sabreman is offline
post #19 of 68 Old 04-19-2013
I used a razor blade with the utility holder. Same type you'd use for scraping windows. It goes pretty quick & like other have said put a tarp under the boat to catch the paint chips & wear a mask. There will be a far amount of dust created when doing this.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #20 of 68 Old 04-19-2013 Thread Starter
casey1999's Avatar
How do you use the shop vac with a scraper and/or sander? Does the sander have an connection point for the hose? For the scraper do you just vac up what fell on the tarp?
casey1999 is offline
Removing Bottom Paint -- Need Input sailingmorning Gear & Maintenance 28 04-08-2012 11:45 PM
Removing 10 coats of bottom paint... patrscoe Gear & Maintenance 36 01-30-2012 07:19 PM
Removing Bottom Paint: How far is too far? wesramm Gear & Maintenance 13 09-01-2008 10:16 AM
Removing Bottom Paint Dan Dickison Gear and Maintenance Articles 0 02-23-2001 07:00 PM
Removing Built-up Bottom Paint Tom Wood Gear and Maintenance Articles 0 09-13-2000 08:00 PM
