Removing Bottom Paint - SailNet Community
 11Likes
post #1 of 68 Old 04-18-2013 Thread Starter
casey1999's Avatar
I need to remove old anti-foul bottom paint prior to applying new paint.
I have seen in the US most people use a sander, while overseas it seems scraping using a large scraper is used. Scraping may be cheaper (last time I sanded and the paint cloggs the sand paper quickly- went through a lot of sanding disc). Scraping might also be environmentally better as it seems to generate less dust.
Comments on best method?
casey1999 is offline
post #2 of 68 Old 04-18-2013
fallard's Avatar
Re: Removing Bottom Paint
I've used a carbide scraper to remove built-up bottom paint on two boats. It's work, but it goes right along and it's a lot less messy than sanding. The carbide really holds its edge and there is no sharpening required. The sharp edge will literally fracture the bottom paint where it's thick and you can scrape the thin parts as if you are planing wood. I don't know what your options are for a power version, but you might damage your gel coat too easily if you aren't properly skilled. You can buy these scrapers at a hardware store, Home Depot, etc. and you can buy replacement blades, but you won't need them if you start off with a new scraper.
fallard is online now
post #3 of 68 Old 04-18-2013 Thread Starter
casey1999's Avatar
Sounds good. I would plan to use the non-powered version. I think I will give it a try.
post #4 of 68 Old 04-18-2013
Newbie
DannyboyUpstate's Avatar
Does the carbide scraper remove the anti-fouling and the barrier coat down to the gelcoat? I have to remove both and start over.
DannyboyUpstate is offline
post #5 of 68 Old 04-18-2013
fallard's Avatar
Another thing: cover yourself as completely as possible. Get a tyvek suit, gloves, a good dust mask, goggles, etc. You will get some fine residue and it will not be nice when you get it in your eyes or nose. It's bad enough on your skin.
You ought to put down a drop cloth to catch the old paint. It should be required if it isn't. I used discarded shrink wrap last time and threw it out with the old paint debris.
downeast450 and gdr like this.
post #6 of 68 Old 04-18-2013
fallard's Avatar
If you get down to a barrier coat (Interlux 2000?) that is well adhered to the gel coat, you'd be better off to switch to sanding if you absolutely have to remove it. If the barrier coat is in good shape, I'd sand it lightly and wash it with the solvent recommended for the new barrier coat.
post #7 of 68 Old 04-18-2013
Newbie
Well, this is a boat I just bought last fall. It sat on the hard for 20 years. It was on the ocean, and I'm lake sailing. I have no idea what the old paint is that's a problem because I want to put VC-17 on it and it must go onto its own barrier coat or it won't be right.
post #8 of 68 Old 04-18-2013
fallard's Avatar
The primer for VC-17m is Interlux 2000E, which is also a barrier coat. If you strip the bottom paint and get to a clean, hard surface and prep it with the appropriate solvent (202)for the 2000, you should be fine. I've used that system for both boats that I stripped. I didn't use VC 17m, but used CSC or ACT ablative copolymer bottom paint (both Interlux products) and it has worked very well.
After you apply several coats of the 2000E, you'll have to let it cure for a while before applying a vinyl bottom paint like VC-17. Interlux also recommends sanding the 2000E with 180 or finer grit before applying the VC-17m.
My suggestion is to read the instructions--something that can be hard for us guys: you won't regret it (assuming you follow the instructions!)
post #9 of 68 Old 04-18-2013
Sabreman's Avatar
A friend gave me this great technique.....
I used a 3/4" wood chisel to "peel" 6 layers of paint. It was very fast, sharpening with a diamond sharpener every 20 minutes or so. I used a carbide tipped paint scraper on the keel and rudder. With 2 of us working, it took 8.5 hours. Then I used a 6" (30% more surface area than an 5") random orbit sander attached to a Shop-Vac. I sanded first with 60 grit, then 120 grit, 6 hours total. The shop-vac prevents sandpaper clogging and extends the life of the disk. Replace disks every 5' feet of hull, never try to make sandpaper "last".
Details and photos are in the link. Click the thumbnails for a larger image: Victoria Bottom Stripping & Fairing
scubadoo likes this.
Sabre 38 "Victoria"
Sabreman is offline
post #10 of 68 Old 04-19-2013
Newbie
Haha. Yeah, I'm with you. A young apprentice at my job used to tell a story about when he was in the military and some rebel (excuse the term) and he were teamed up and the guy told him "INSTRUCTIONS?! THAT'S THE FIRST THING IN THE TRASH!!!" So we say that all the time.
Removing Bottom Paint -- Need Input sailingmorning Gear & Maintenance 28 04-08-2012 11:45 PM
Removing 10 coats of bottom paint... patrscoe Gear & Maintenance 36 01-30-2012 07:19 PM
Removing Bottom Paint: How far is too far? wesramm Gear & Maintenance 13 09-01-2008 10:16 AM
Removing Bottom Paint Dan Dickison Gear and Maintenance Articles 0 02-23-2001 07:00 PM
Removing Built-up Bottom Paint Tom Wood Gear and Maintenance Articles 0 09-13-2000 08:00 PM
