Cutting a through-hull for bilge pump outlet - Page 2 - SailNet Community
 2Likes
post #11 of 17 Old 04-20-2013
Send a message via Yahoo to dacap06
When I replaced my bilge pump through hull a while back, I used 3M 4000 Marine sealant. It resists UV degradation better than 4200 does and is about as strong. I second using a hose loop as high as your waterline when heeled is likely to be. I had the backflow problem too until I finally figured out where the water was coming from.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #12 of 17 Old 04-20-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Cutting a through-hull for bilge pump outlet
my boat uses a manual pump.. which is good as there are no other through hulls (except for an above waterline sink) but I was debating putting an electric pump in as a "just in case" for storms and times when I may be out of state working.
it's a 24foot Sea Sprite and I was thinking of running the hose aft to the outboard engine well. Do you think a pump can push that much water? (approximatly 10 feet)
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #13 of 17 Old 04-20-2013
No more curry buffets
Ritchard's Avatar
Both my electric bilge pumps push water around 19 or 20 feet of hose run from the bilge to the transom, is that what you mean? I think it's pretty common. I'd not be without at least one electric bilge pump wired straight to the battery (with a fuse). Cheap peace of mind when away from your boat.
I am not sure about outletting into the engine well. Is there anything stopping you from going to the transom or thereabouts? The engine well may be fine, I don't have any idea what yours is like/how it drains, etc.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #14 of 17 Old 04-20-2013
it's a big open hole in the hull, Being as it is about 2 feet deep, that would be two feet less hose between the pump and outside as opposed to going all the way to the transom
Art Haberland
post #15 of 17 Old 04-21-2013
Senior Slacker
SlowButSteady's Avatar
Folks usually plumb the bilge pump to the transom because it's almost impossible for the transom to be underwater (unless the boat is far beyond any help a little bilge pump might provide). As long as the engine well never gets enough water to potentially start a back siphon via the bilge pump hose, and you don't mind your outboard getting sprayed with bilge water, it should be fine.
However, one added advantage of going to the transom is that if the pump starts to continuously spew water out (i.e., you have a serious leak and the pump is always on) someone might notice and get word to your marina and/or you before your boat sinks. Such an event happened on my dock almost a year ago; another dock neighbor noticed a bilge pump running almost continuously, he pointed it out to the marina manager, who called the boat's owner, and disaster was avoided (I heard that it was a faulty knotmeter sender).
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #16 of 17 Old 04-21-2013
I dont think that 2 more feet of smooth bored hose traveling laterally is going to make much difference in pumping. Corrugated hose might. It's rise that makes the most difference and you should already have an anti-siphon loop that is higher than the outlet.
Jeanneau 54DS
Minnewaska is offline
post #17 of 17 Old 04-21-2013
that's just it. I have a manual pump that requires me to put a hose over the side before pumping. So I am trying to decide the best course of action for a little piece of mind. I wanted to go to the stern to keep heel from affecting the flow.. so maybe I will go to one side of the engine well rather than right to it
Art Haberland
One-way valve in bilge pump outlet line? MarkSF Gear & Maintenance 1 01-03-2013 06:39 PM
bilge pump discharge thru hull raayres18 Gear & Maintenance 13 01-02-2011 10:53 PM
Check alve - in outlet of the bilge pump velero Gear & Maintenance 11 04-03-2010 08:06 PM
Bilge Pump Discharge - New Thru Hull ??? Terry Clarke General Discussion (sailing related) 4 05-10-2003 05:07 PM
Bilge Pump Discharge - New Thru Hull ??? Terry Clarke Gear & Maintenance 3 05-01-2003 06:25 AM
