Cutting a through-hull for bilge pump outlet - SailNet Community
 2Likes
post #1 of 17 Old 04-19-2013 Thread Starter
Ok, going to cut a through-hull for the automatic bilge pump (3/4" outlet). Guessing I should place it somewhat near and parallel to the manual pump outlet. This will be a plastic fitting, to match the other one. Please pardon the many questions below!
3/4" hole saw?
Drill from inside or outside?
Drill in reverse when it first touches the fiberglass?
Tape off the target area to protect the gelcoat?
Do you put any epoxy or sealant inside the hole prior to installing the through-hull fitting?
Thanks in advance. This is a nerve-wracking procedure for me.
FirstCandC is offline
post #2 of 17 Old 04-19-2013
Re: Cutting a through-hull for bilge pump outlet
My answers in blue
3/4" hole saw?
- I would prefer a hole saw
-both - start from one side, when the center bit is through and you have a good grove, switch side
- Yes, less chance of damaging the gelcoat, drill pilot hole first with a normal drill bit if necessary. You can do the whole cut in reverse - less chance of the drill starting to kick
- No I don't do that
- If it is only fiberglass it is not necessary, if cored then Yes
FirstCandC likes this.
knuterikt is offline
post #3 of 17 Old 04-19-2013
Aspiring to be a Mexican
sww914's Avatar
Drill an 1/8" hole first. If you make a mistake, it's really easy to fix with a dab of Splash Zone or similar.
sww914 is offline
post #4 of 17 Old 04-19-2013
chef2sail's Avatar
I do tape the outside to prevent splintering and dust
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #5 of 17 Old 04-19-2013
No more curry buffets
Ritchard's Avatar
I have done this once each last year and this year. I use the next-size-up hole saw from the thru hull side of the thru hull. I think 3/4 is too tight, a one inch leaves only 1/8" on either side of the hole, which allows for a little caulk to squeeze into that gap. I also use a backing plate for good measure, though for a small thru hull under little stress it is not strictly necessary. Last year was a piece of 3/8 ply pre-holed and liberally coated with epoxy. This year was a piece of 3/8 fibreglass sheet, again pre holed. These will later be bedded in caulk.
Drill your hole. You can go backward, or just start slow. I go from outside and go slow. Gel coat is relatively soft, and cuts easily. Once through the gel coat, (my hull is solid glass) I stop and remove the saw frequently to let it cool - it's a high friction situation. Going slowly I have not had any tear-out or splintering experience.
Once the hole is cut, mask all around the hole a couple inches. Place the thru hull in place and hold it firmly with one hand while you trace around it with a razor knife into the masking tape. Remove the thru hull and remove the tape you've scribed around the hole. Goop up the thru hull, flange and shaft with caulk. Put it in place. Have a friend you don't like very much or a teenager that needs to learn a lesson climb into that tiny locker to bed the backing plate and the shaft and spin on the nut. If it's a nylon or marelon thru hull, don't overtighten and deform the threads. Even if it's bronze don't overtighten, you don't want to squeeze all the caulk from between flange and the hull, or between the backing plate and the hull. Enough caulk has to remain to do its job.
Clean up the excess caulk with paper towels, then a rag and some solvent. Stand back and admire your manliness.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #6 of 17 Old 04-19-2013 Thread Starter
Thanks to all. Ritchard, which caulk do you prefer?
post #7 of 17 Old 04-19-2013
Ideally, you want the outlet to remain above the waterline when heeled over. Not sure if your current manual outlet is.
If you have a cored hull, you are going to want to dig out some of the core, leaving the glass at the correct size and then fill the core back with thickened epoxy.
Unrelated to your question, but be sure to use smooth bilge hose or you lose much of the pumping ability. You also lose flow rate, the higher you have to lift it to the outlet.
Jeanneau 54DS
Minnewaska is offline
post #8 of 17 Old 04-19-2013
Senior Slacker
SlowButSteady's Avatar
Originally Posted by Minnewaska View Post
...Unrelated to your question, but be sure to use smooth bilge hose or you lose much of the pumping ability. You also lose flow rate, the higher you have to lift it to the outlet.
It sounds like you are installing a little automatic pump to take care of the stray drips, et cetera. If so, and to the extant that you can, route the hose so that it's highest point is higher than the thru-hull and as near as possible to the pump (i.e., the section of hose between the pump and the high point should be as short as possible). Then route the hose so that the water continuously flows down to the thru-hull from the high point. That way you will have the minimum amount of "back-slosh" going back into the bilge when the pump turns off. If the thru-hull is the highest point in the system the contents of the entire run of hose are likely to wind up back in the bilge at the end of each cycle.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #9 of 17 Old 04-20-2013
Be absolutely sure that the outlet is above the water line at all points of sail, or a least there is a loop inside the boat the accomplishes the same.
If you don't, what happens is one day you are out sailing healed over on a beautiful day and the bilge starts filling with water as a nice siphon sets up.
Don't ask me how I learned this please
capecodda is offline
post #10 of 17 Old 04-20-2013
Ritchard's Avatar
Per your question above, I would use 3M 4200. For me it has worked well, and it's readily available. Others may have better suggestions.
I second the ideas about routing a loop in the plumbing, and perhaps more crucial would be excavating a half-inch of core material around the hole you've just cut should you in fact have a cored hull. I just did a little reading, and I think you'll find that a '77 C&C 27 will have a solid core.
http://www.cncphotoalbum.com/reviews/c&c27.htm
Ritchard is offline
One-way valve in bilge pump outlet line? MarkSF Gear & Maintenance 1 01-03-2013 06:39 PM
bilge pump discharge thru hull raayres18 Gear & Maintenance 13 01-02-2011 10:53 PM
Check alve - in outlet of the bilge pump velero Gear & Maintenance 11 04-03-2010 08:06 PM
Bilge Pump Discharge - New Thru Hull ??? Terry Clarke General Discussion (sailing related) 4 05-10-2003 05:07 PM
Bilge Pump Discharge - New Thru Hull ??? Terry Clarke Gear & Maintenance 3 05-01-2003 06:25 AM
