Oil in the sump - SailNet Community
Blogs
Old 06-06-2004
sinewave2 is on a distinguished road
Oil in the sump
put the boat in to day and went to check the oil before starting it up and found no oil in the engine ! but there was oil in the engine sump bilge, also with the anti freeze. could this be just a lose oil sump fitting or am i in for more work that i want? It''s a 87 universal M-18
Old 06-06-2004
DelmarRey's Avatar
DelmarRey is on a distinguished road
Oil in the sump
With both antifreeze and oil in the bilge it could be a few of things.
1) a badly blown head gasket
2) a cracked block (hope not!)
3) a cracked head
The next question would be: were you running the engine on no oil.
Do you have an oil pressure alarm? And does it work?
Old 06-06-2004
hamiam is on a distinguished road
Oil in the sump
I had a similiar situation when the raw water pump belt broke and the engine overheated causing the head to warp.
76 Grampian 28? gandydancer Boat Review and Purchase Forum 7 06-25-2011 03:30 PM
Help figuring our which Irwin this is? trecksail Boat Review and Purchase Forum 9 02-01-2005 03:50 PM
Perkins 4-108 Oil Sump Strainer ABullard Gear & Maintenance 1 04-20-2004 02:00 PM
Internal Ballast vs. External Ballast windship General Discussion (sailing related) 3 09-15-2002 05:33 PM
Installing a shower sump? AndrewB Gear & Maintenance 4 10-09-2001 08:31 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
