Grounds and Bonding - SailNet Community
post #1 of 2 Old 04-19-2013 Thread Starter
casey1999's Avatar
Grounds and Bonding
Are all of your metal underwater fittings bonded to a common ground? Some say you should, others say it could lead to corrosion issues. What do you do and have you ever had a corrosion problem?
Also, currently my SSB is grounded to the lead keel via a stainless steel keel bolt. Again I have read this could be a problem. I do have corrsion on the keel bolt nut in my installation (somthing I will correct) but I believe it is because the ground strap is copper and keel bolt nut is stainless. I read where you can put capacitors on the SSB ground strap to pass RF current but to stop DC stray currents. Would anyone know what size capacitors and how many to use- I have misplaced the article.
casey1999 is offline
post #2 of 2 Old 04-22-2013 Thread Starter
casey1999's Avatar
Re: Grounds and Bonding
I found the article if any one is interested:
The West Advisor: Marine Grounding Systems
Best Beginners sailing grounds? multiboat General Discussion (sailing related) 25 12-21-2012 06:08 PM
cruising grounds for kids beachpotato Cruising and Sailing with Children 4 06-23-2010 05:37 PM
Nice cruising grounds aren't they?? Giulietta General Discussion (sailing related) 4 02-03-2009 11:29 PM
Florida Cruising Grounds stlcat22 Cruising & Liveaboard Forum 0 01-05-2007 08:54 PM
SSB Radio Grounds Sue & Larry Seamanship Articles 0 10-10-2001 08:00 PM
