What size boom vang - Page 2 - SailNet Community
post #11 of 15 Old 04-20-2013 Thread Starter
Don't think so on the Cunningham or the downhaul
Ei Leen is offline
post #12 of 15 Old 04-20-2013
Re: What size boom vang
Originally Posted by Ei Leen View Post
I don't think twisting will be a problem since I have a traveler bar across the back
Your traveller is only effective in helping control twist if the boom is still above it. Once you're going downwind and the sheet's let off there's very little downward component to the mainsheet pull. This is where a vang is helpful, it can be used to limit boom lift, provide leech tension and limit/manage twist.
If I had to pick just one, it would be the vang. A powerful easy-to-use vang is like having an infinitely wide traveler.
As an example, look at a competitive Laser dinghy.. a pretty mediocre traveler arrangement, but you'll see a high power vang.
Faster is offline
post #13 of 15 Old 04-20-2013 Thread Starter
Thanks for the advice. Cripe there's so much to learn. I'm taking it all in as fast as I can. There's a huge learning curve just with the terminology :/
Ei Leen is offline
post #14 of 15 Old 04-21-2013
no longer reading SailNet
Alex W's Avatar
Faster: I hadn't thought about that kind of jybe, that's why I come back here and learn more. I can see how a vang would prevent that, but it's pretty secondary to it's normal purpose or learning how to avoid accidental jybes.
Alex W is offline
post #15 of 15 Old 04-21-2013
True, but such a gybe is almost more likely to occur early in your sailing learning curve rather than later.. something as simple as the vang can prevent that 'unnecessary' occurrence. And it's most likely and most potentially damaging during a DDW - mainsheet fully eased situation.
If a good vang isn't in the budget, a simple fixed strop will perform that function alone...
Faster is offline
Boom Vang vs Boom furling? Windkiller General Discussion (sailing related) 7 07-26-2011 08:27 PM
Boom Vang SouthBrooklyn Gear & Maintenance 7 11-03-2010 09:57 AM
Boom Kicker Boom Vang dwottavian Gear & Maintenance 5 01-11-2010 01:48 PM
[New Video Out] The Boom Jack or Boom Vang Giulietta General Discussion (sailing related) 8 01-23-2008 11:33 PM
Boom Vang z1nonlyone Gear & Maintenance 5 08-21-2003 09:51 AM
