waxed gelcoat? - SailNet Community
post #1 of 3 Old 04-20-2013 Thread Starter
bristol299bob's Avatar
waxed gelcoat?
I will be doing a small fiberglass repair next weekend. Its a little bigger than a sq ft. I'll require a layer or two of fiberglass. I intend to finish it with a layer or two of gelcoat. Its that second coat of gelcoat that i'm wondering about.
I've got some "waxed gelcoat" .... gelcoat with wax mixed in. I've used it a few times already. It air dries; my understanding is that the wax migrates to the surface so that it will cure. So no need to overspray with PVA. I've only used it as one coat so far.
With this stuff, what about a second coat? Can I do it while the first is still tacky? or will the wax interfere? Is it better to wait until fully cured, and clean with acetone before the second coat?
or should I skip this stuff altogether and go with "regular" gelcoat and spray the final coat with PVA?
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
post #2 of 3 Old 04-21-2013
Have a go and DIY .....
Re: waxed gelcoat?
You can use the waxed gelcoat as a second coat
If you need to apply another coat the waxed gelcoat will have to be well sanded.before applying other coats.
I use the same waxed gelcoat on several coats each time sanding down until I have a smooth surface that i can then use finer grade wet and dry sandpapers on and then when all is looking good i then polish it with a compound cutting paste until it shines.
macwester26 is offline
post #3 of 3 Old 04-21-2013
Re: waxed gelcoat?
I'm going to be making some gelcoat repairs myself soon and have asked the same question about using multiply layers. The latest and greatest info out of Jamestown Distributors indicates that I can use a prevail sprayer with a wax gel and apply muti layers without sanding as long as each coat is put down within minutes of each other. I want to use thin coats however I also want to have sufficient layers to gain maybe a 20 mil thickness. Not sure how many layers would be needed for that thickness. Still learning.
lancelot9898 is offline
Gelcoat Mildew-I'm so sick of gelcoat mildew bwindrope Gear & Maintenance 45 11-15-2015 04:28 PM
Waxed vs unwaxed gel coat jarcher Gear & Maintenance 5 04-30-2009 07:08 PM
awlgrip or gelcoat? slokaj Gear & Maintenance 10 04-20-2009 02:56 AM
gelcoat or not to gelcoat? marcusn Gear & Maintenance 2 05-30-2008 02:44 AM
New Gelcoat vs Painting dm567 Gear & Maintenance 7 08-08-2007 09:49 PM
