seeking advice on protecting my keel - SailNet Community
post #1 of 6 Old 04-21-2013 Thread Starter
I have a 1986 J-22 and I've noticed recently that the material protecting the (cast iron?) keel is in need of repair. An image of the area needing repair is below. As you can see, it's down to the metal, and it looks like there is some light oxidation there. My best guess at the protecting material is that it's tar since it feels rubbery and I was able to tear it off. What I'm thinking of doing is using a grinder to smoothen the edges and remove the oxidation, and then use epoxy. Does this sound like a good or bad idea?
https://www.dropbox.com/s/m0mj65og0c...2012.07.54.jpg
eggman2001 is offline
post #2 of 6 Old 04-21-2013
Greenflash35's Avatar
Re: seeking advice on protecting my keel
can't remember the name, there's an acid primer for iron keels.
GreenFlash35
Greenflash35 is offline
post #3 of 6 Old 04-21-2013
There's not enough 'rust' there for that to be an iron keel... I wouldn't have thought that the Js used iron anyway (but not positive about that). That's a pretty big chunk of fairing knocked out of there, grinding back and refilling/fairing is straightforward enough.
Faster is offline
post #4 of 6 Old 04-21-2013
That looks nothing like my iron keel. That is something else.
benesailor is offline
post #5 of 6 Old 04-21-2013
tommays's Avatar
Trust me it is lead never seen anybody muck one up quite that bad without a lot of big rocks involved a bunch of times
Your going to have to remove all the lose fairing material clean things up and do a WHOLE bunch filling and sanding
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 6 Old 04-22-2013
J/22's have a lead keel. Fairing compound has been knocked off probably by impact with a hard object. Remove the fairing material which is not tightly bonded to the keel and refair. This previous post covered the techniquue; How do you fair a keel? Particularly heed post #3 by Jeff H.; he's got it right
Hudsonian is offline
Seeking Advice on Living on an Yacht seti668 Boat Review and Purchase Forum 6 06-08-2011 07:27 PM
Another newbie seeking boat advice ssll3 Boat Review and Purchase Forum 6 01-05-2010 10:47 AM
Seeking Advice On Beneteau Keel Types Ianconboy Beneteau 2 09-17-2007 06:50 PM
SEEKING ADVICE! seawindgr Boat Review and Purchase Forum 0 08-31-2002 10:57 PM
Seeking Jib Traveler Advice dchew Racing 0 05-05-2002 06:03 AM
